Skynet Skynet v8 - Router Firewall & Security Enhancements
I have the almost same set up as John and see the same issues. I think there is a race condition with mounting the usb device. In the firewall.sh line 130 there is a check to see if the string $skynetloc is empty (-z). Is this check correct? If the string is empty then we do not want to use it within the if statement. Also the wait loop for the usb is not executed.
Thanks in Advance.
Change the -z to -n and see if it improves things.
I changed it to [ ! -z $skynetloc ] and the firewall survives many reboots. There is still an issue with the lock file (/tmp/skynet.lock) being incorrectly detected but the firewall debug info extended show all green. I would place it in the "not seen to fail" category at the moment. Hopefully this helps someone with more knowledge of the code.
I can consistently reproduce my issue by following these steps:
  1. Switch to the custom filter list: https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list
  2. After some random time (max. 1 hour), all of my devices (PCs, laptops, and smartphones) lose their connection to the router.
Although the SSID is still visible, the router no longer assigns an IP address.
I also don’t receive an IP address when connecting directly to the router via an Ethernet cable.
Everything works fine when using the default filter list.
I don't see anything unusual in syslog.
Edit:
Skynet v8.0.4 seems to have solved this problem.
After updating to Skynet 8.02, I encountered the following error:
IPTables Rules | [Failed]
A few minutes later, this followed:
IPSets | [Failed]
After some troubleshooting, I traced the issue to my long country blocking list:
 Banned Countries; cn ru sc ua ee ls gr ba bg hr cz ge hu kg lv lt mc kp ro sk vn uz lk br ar cl co pa py uy iq ir jm
It seems the update may have introduced a change in how large IP sets are handled.
Solution:
  1. I manually removed the country block list.
  2. Reloaded Skynet.
  3. Then, I re-added the countries gradually, starting with just a few to confirm stability.
  4. Once confirmed, I reloaded the full list.
Since then, everything has been stable and working as expected.
I currently have no problems on my AX88Pro with defaults only, however previously when running my AX86 and a list of 26 banned countries my throughput was noticeably reduced. Removed the country bans and went with default lists and throughput issue eliminated. Is it possible that one of the reasons that posters with long lists of bans either countries or other lists have routers that just don't have the processing to handle the necessary checks?
Regarding the Lock messages from my last message they are always owned by the running process. These messages are therefore misleading. I have placed a check if [ $locked_pid -ne $$ ]; then ... fi around the messages in Load_Menu and the debug/info code. Once again if someone could review and comment.
With these additional changes the firewall appears to be running. I am on the Firmware Version 388.10_2 for all those wondering about 3004 vs 3006.
Thanks in Advance.
Logging of invalid packets results in
[*] Rule Integrity Violation - [ #24 ]
regardless of whether you use the default or custom blocklists
# iptables --line -nL logdrop
Chain logdrop (10 references)
num  target     prot opt source               destination
1    LOG        all  --  0.0.0.0/0            0.0.0.0/0            state NEW LOG flags 7 level 4 prefix "[BLOCKED - INVALID] "
2    DROP       all  --  0.0.0.0/0            0.0.0.0/0
I am seeing OUTBOUND blocks in the private LAN br0 from LAN hosts to broadcast addresses.
224.0.0.1
224.0.0.22
224.0.0.251
239.255.255.250
239.255.255.251
255.255.255.255
224.0.0.1
224.0.0.22
224.0.0.251
239.255.255.250
239.255.255.251
255.255.255.255
Thank you for the very specific bug reports. I've updated the banmalware regex to include even more crazy addresses that should never appear on a blacklist like this. I've also corrected the error detection as we were scanning the raw rules not filter.
Thanks in Advance.
Another good find, thanks. During the update this was accidentally changed from
if [ ! -d "${skynetloc}" ] || [ ! -w "${skynetloc}" ]; then
v8.0.3 is live with all these changes.
Thanks for your hard work on this great software.
I cant measure any throughout difference with Skynet enabled or disabled using the biggest country and malware lists I could find.
Wan;
LAN;
Add me to the list of people with issues running Skynet 8.0.2. I had a power outage today. When power came back and everything booted up, skynet failed to load. No GUI, and the same errors previously posted to this thread. I've been running the stock lists, no custom lists.
I reinstalled through AMTM and everything seems to be back. At least until the next reboot.
8.0.3 should fix your issues.
Are you running 8.0.3 now?
I hadn't even noticed 8.0.3 was released. I just re-installed in terminal (option 14 in the menu) and was off to the races. Just ran the update to 8.0.3. Thanks for the heads up.
I've pushed v8.0.4 which should address all outstanding bug reports;
Show banned countries and custom filter list url in debug info
Show skynet max log size
Improve country ban input validation
Banning countries no longer requires quotes, eg
firewall ban country xx xx xx xx
Fix syslog auto-correction by updating syslog exe path for busybox
Fix IOT input having private addresses filtered out
Fix some rule checking logic
The last update to 8.0.4 was smooth, no issues right now to report.
Edit: Still experiencing issues with IoT block. Ipset fails as soon as I add an ip address.
Can you show me an example? Can't reproduce on my end.
skynet@GT-BE98-38A4:/tmp/mnt/USB/skynet# firewall settings iot ban 192.168.1.222
# Router Firewall And Security Enhancements #
# By Adamm - https://github.com/Adamm00/IPSet_ASUS #
# 17/11/2025 - v8.0.4 #
IOT Blocking List Updated
Saving Changes
[#] 169674 IPs (+0) -- 2167 Ranges Banned (+0) || 335 Inbound -- 1 Outbound Connections Blocked! [settings] [2s]
skynet@GT-BE98-38A4:/tmp/mnt/USB/skynet# ipset -L | grep "IOT"
192.168.1.23 comment "IOTBan: Nov 17 14:03:31"
192.168.1.222 comment "IOTBan: Nov 17 15:12:01"
192.168.1.111 comment "IOTBan: Nov 17 14:03:04"
