SR20000G(High Power 600mW) 5G extending connection issue
silentlookr
I connected my SR20000G to my ASUS RT-AC87U. When I scan using the extender it finds both 2.4gh and 5gh. However after inputting the password it's not able to connect my asus router to the 5G. The password for both 2.4 and 5 is the same. I copy the code directly from the router so there is no issue with the code . Here is what I see when i log in to my SR router
Here is what I see on the SR
May 2 15:25:21 wlan0-vxd: A STA is rejected by 802.1x daemon - 2C:4D:54:82:3B:74
May 2 15:25:23 wlan0-vxd: WPA-none PSK authentication in progress...
May 2 15:25:23 wlan0-vxd: Open and authenticated
May 2 15:25:28 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:30 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:32 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:33 wlan0-vxd: WPA-none PSK authentication in progress...
May 2 15:25:33 wlan0-vxd: Open and authenticated
May 2 15:25:38 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:40 wlan0-vxd: WPA-none PSK authentication in progress...
May 2 15:25:40 wlan0-vxd: Open and authenticated
May 2 15:25:46 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:48 wlan0-vxd: WPA-none PSK authentication in progress...
May 2 15:25:48 wlan0-vxd: Open and authenticated
May 2 15:25:48 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:50 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:52 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
May 2 15:25:59 wlan0-vxd: A STA is rejected by 802.1x daemon - 2C:4D:54:82:3B:74
May 2 15:26:04 wlan0-vxd: Deauthenticated by AP - 2C:4D:54:82:3B:74
On the 87U, make sure both bands use the same WPA scheme (WPA2-AES), and the same passphrase if running common SSID on both bands.
And this would be relevant to anyone working with a dual band Router/AP and extender...
@silentlookr - The Asus and Netgear subforms are vendor specific - for questions like this, the top level general wireless forum might be a better place...
Yes both 2.4 and 5 is WPA2-AES. Also uses the same passphrase. Oh well i guess i am stuck just using 2.4 as even after I did hard reset on both routers, it would still not connect.
