TAILMON TAILMON v1.3.1 -Mar 1, 2026- WireGuard-based Tailscale Installer, Configurator and Monitor (Available in AMTM!)
Yes, I tried adding all those kinds of those types of commands after those listed. The only fix was to end the autoupdate routine with a tsdown. That way, the main loop detects this and restarts tailscale. I agree it's must be some kind of cache issue with either tailmon or tailscale.
I'm sure a reboot would also work but 1) it's overkill as the change above works for me even though I don't know why and 2) I wouldn't be able to do so remotely if I can't access the router.
Thanks,
Rung
If it helps, here is my config file:
track=0
keepalive=1
timerloop=60
logsize=2000
autostart=1
schedule=1
schedulehrs=3
schedulemin=30
updatetm=1
updatets=1
amtmemailsuccess=1
amtmemailfailure=1
ratelimit=0
tsoperatingmode="Userspace"
persistentsettings=1
exitnode=1
advroutes=1
accroutes=0
precmd=""
args="--tun=userspace-networking --state=/opt/var/tailscaled.state --statedir=/opt/var/lib/tailscale"
preargs="nohup"
routes="192.168.1.0/24"
customcmdline=""
That's interesting. I'll have to check that out, and see if it restarts the script itself too in that situation. That might be a more forceful way of getting these services restarted.
New beta available with some new additions made by @rangermix!
What's new:
v1.3.1b1 - (TBA)
- MINOR:
Thanks to a contribution from @rangermix, the capability of forcing the router to use IP Forwarding if it is disabled has been added. His addition will check for the existence of the /proc/sys/net/ipv4/ip_forward (and ipv6) files, and checking they are both set to "1" before enabling this functionality by adding some statements to your init-start file. So this may require a reboot before it will work completely. Apparently this has been a hang-up for several folks now, and this seems to be a working fix. For others (like me), this setting was already enabled, and this code would not interfere with that. Another interesting note is that @rangermix believes this behavior stems from routers being configured in a "repeater mode", and may have these settings turned off by default.
Download link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/TAILMON/develop/tailmon.sh" -o "/jffs/scripts/tailmon.sh" && chmod 755 "/jffs/scripts/tailmon.sh"
I'm happy to see I have ipv4/ip_forward existing and set to one (and don't seem to have any issues with Tailscale). By the way, do you know the symptoms if this is an issue for someone?
Note: I don't see a ipv6/ip_forward entry. Is it because I don't have ipv6 functionality enabled? Does the code check for that?
I think @rangermix would need to fill you in on some more of the symptoms, but after some frustration trying to troubleshoot this issue, he found that this fix solved it for him as well:
https://www.snbforums.com/threads/t...d-monitor-available-in-amtm.92874/post-972216
Good call... it's actually located under:
/proc/sys/net/ipv6/conf/all/forwarding
Updated to beta. Checked out a couple of functions. All still working great as usual!
Per my check at the time it was raised, mine are both 1 for IPv4 and IPv6.
Good on you @Viktor Jaep for gnawing away at this since October! Not suggesting you’re slow, just dogged…
Truthfully, I wasn't really considering implementing it, but it seems there's more than just 1 person now that has come across this. Huge thanks to @rangermix for taking on the task of getting something formally implemented within TAILMON. :)
Hi All - I really appreciate Tailmon and have been running Tailscale on my router for a while. I've had to compile my own Tailscale due to CG-NAT IP range conflicts as tailscale takes over the whole 100.64.0.0/10 range
I wanted to downgrade recently so I used Tailmon to go back to version 1.84.0 (successfully) but when I wanted to install my custom tailscale 1.90.9 ipk, Entware still thought I was on 1.92.3. I use the command:
Opkg install tailscale_1.90.9.ipk
Error:
Not downgrading package tailscale on root
To get around this I fully removed tailscale and then installed again. My long winded question is, does anyone know where Entware might be storing the higher version number after using Tailmon to downgrade? It looks like remnants remain during a downgrade
Entware is completely unaware of any updates or downgrades that aren't performed by the opkg command, e.g. using tailscale update.
To see what Entware thinks is the current version use opkg info tailscale. To force Entware to install an older version use the --force-downgrade option.
FWIW, I’m using 1.92.3 and entware latest that it would install on a first Tailmon install is 1.82.5-1.
If I'm not mistaken, the --force-downgrade option doesn't really work. (Never has worked for me). When downgrading, TAILMON actually stops and forcefully removes the old versions, and downloads the tgz files directly from tailscale.com, unpacks them and moves them into the right place.
Are you saying that TAILMON issues an opkg remove tailscale command, or that it just deletes the files without updating Entware?
In order to leave the environment in place (and intact), TAILMON does not perform an opkg remove tailscale command, but stops the services, removes the files, and replaces them with the user-specified version.
Just upgraded my internet to T-Mobile Fiber and was not aware that they use CG-NAT.
I have a handful of remote services I regularly use and to fix the issues caused by CG-NAT I plan on using Tailscale. Installed TAILMON then chose option 1 to install Tailscale. Then this...
Any help on my next step would be greatly appreciated.
Thanks in advance, Bob
Actually it just sounds like a network error (Internet).
I just tried https://entware.diversion.ch/aarch64-k3.10/tailscale_1.82.5-1_aarch64-3.10.ipk in a Browser and immediately got the package so I think it’s available.
Try again a wee bit later, an hour or so?
Agreed, @BobWadd... Make sure you can resolve entware.diversion.ch from your router. Once that connection is restored, you should be able to download the install package.
Tried to install again this morning and it installed without issue.
I've just been having so many issues getting things to work again with T-Mobile Fiber that I'm getting frustrated.
Thanks again!
I imagine not, but would it be possible to wire a client through the guest network on tailscale on the router?
If not, I suppose in order to do that you'd have to just install tailscale on a home device connected to the guest network?
