TAILMON TAILMON v1.3.1 -Mar 1, 2026- WireGuard-based Tailscale Installer, Configurator and Monitor (Available in AMTM!)
Thanks this worked!
Just for the record, v1.86.0 seems to work OK for me getting to my router/devices behind my router from remote.
@rung ... you can also downgrade this way:
tailscale update --version 1.84.0
Unfortunately, this command didn't let you downgrade only upgrade. I successfully used Colin's method.
However, I found the version was not the issue but I did fix it somehow:
1) downgrade by copying the binaries then restarting tailscale in tailmon. Saw a warning about mismatched versions so I restarted twice
2) Found issue still existed
3) Unsuccessfully tried to upgrade in tailmon. An error about some cache directory being readonly
4) Completely shutdown tailmon and then restarted tailmon
5) Upgrade now worked in tailmon with same warning about a mismatch.
6) Can't remember, may have restarted tailscale again here
Now it works again! No idea what was wrong before.
Thanks,
Rung
Thanks,
Rung
Looks like that feature may be broken... but according to the docs, it should be possible:
Glad things are back up and running again! :)
Small patch to help with some message rate limitations in the situation of a network outage, as reported by @JGrana. Thank you!
What's new?
v1.1.1 - (July 26, 2025)
- PATCH:
Modified a section of code that checks to see if the Tailscale service is dead, and tries to restart the service. @JGrana found that in a case of a network outage, that TAILMON will flood you with messages indicating that it tried restarting the service, only to have it loop until network connectivity is restored. This puts a rate limiter on to only attempt this every 60 seconds. It will also execute a fresh version of the script each time to eliminate any factors around that.
Download Links (or update directly within TAILMON, AMTM or just let it autoupdate itself):
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/TAILMON/master/tailmon.sh" -o "/jffs/scripts/tailmon.sh" && chmod 755 "/jffs/scripts/tailmon.sh"
Significant Screenshots:
None today! :)
I tried Tailscale / Tailmon today, and so far it’s working correctly.
During setup, I was experimenting with CIDR blocks and likely ran into a situation where Tailmon got stuck and began restarting repeatedly. I had mistakenly configured the CIDR as 192.168.1.0/21 instead of the correct 192.168.0.0/21. After restarting Tailmon, it failed to recover and entered a restart loop, without the option to access (C)onfiguration. I had to use the -setup parameter to revert to the correct CIDR (192.168.0.0/21 in my case).
Not a major issue, but just something I observed.
Thanks for reporting, @salvo... you actually hit that screen that now provides a limiter, and runs every 60 seconds instead of continuously. Configuration errors are easy to make with Tailscale, especially when you start adding custom switches. Glad you were able to get it resolved and back to stable again. ;)
@Viktor Jaep looks like Tailscale has pulled the 1.86.0 update...
Tailscale Changelog
Tailscale v1.86.0
Update instructions
Note: Tailscale halted the rollout of version 1.86.0
for macOS on July 25, 2025,and for all other platforms
on July 28, 2025, due to multiple regressions.
Resulting in an amusing/confusing tailmon message for me overnight after the daily update check:
SUCCESS: Tailscale was successfully updated via autoupdate from v1.86.0 to v1.84.0
Date/Time: Jul 29 2025 05:10:14
SUCCESS: TAILMON has successfully autoupdated Tailscale to the latest version.
Sent by the "tailmon.sh" script.
From the "AsusRouter" router.
2025-Jul-29 Tue 05:10:14 AM UTC
It wasn't - I rebooted just to be sure and then I'm still on 1.86.0 if I run "tailscale version" manually.
Probably an edge case you hadn't quite foreseen?
I'm thinking I'll get the "upgrade" emails again when it tries again tomorrow morning perhaps?
Plus with the command line downgrade not working...
Not sure if we should all be downgrading to 1.84.0 or not pending them squashing all the "multiple regressions"...
@Viktor Jaep And just because I've actually been catching up with AMTM add-on emails...
Looks like every time tailmon manages a successful Tailscale binary update (including this morning's supposed downgrade to 1.84.0 - NOT) I also get the following email sent at the same time, even though my setup has always been Custom and has never changed - I probably don't need to be reminded if the "Mode" stays the same, even though the Senior Moments are starting to creep in occasionally! :p
SUCCESS: Tailscale Operating Mode changed to Custom Mode
Date/Time: Jul 29 2025 05:10:26
SUCCESS: TAILMON has changed Tailscale Operating Mode to Custom mode
2025-Jul-29 Tue 05:10:26 AM UTC
Tailscale Changelog
Tailscale v1.86.0
Update instructions
That is indeed a unique edge case I wasn't prepared for. I would have always assumed that the version you're about to download would be newer/higher than the one on your system. As you can see during the autoupdate below, it even complains that no update is needed, but TAILMON is dumb, and proceeds to think that the upgrade was successful afterall. If you want to avoid this, then yeah, you would need to uninstall tailscale, and upgrade to v1.84. Or you can just turn off autoupdate for the time being.
That certainly is an annoyance. I get those too, and am annoyed as well. ;) I'll take care of this!
Well you know @Viktor Jaep, OCD and all so - managed to downgrade to 1.84.0 manually using my own (probably ham-fisted) variation on the @ColinTaylor instructions ...
Download https://pkgs.tailscale.com/stable/tailscale_1.84.0_arm64.tgz and extract tailscale and tailscaled. Copy them both to /opt/bin. Restart Tailscale.
1. Downloaded https://pkgs.tailscale.com/stable/tailscale_1.84.0_arm64.tgz and extracted the "new" (older) tailscale and tailscaled binaries to a temp location.
2. Deleted old files /opt/bin/tailscale and /opt/bin/tailscaled.
3. Moved the two new files to /opt/bin
4. Made them both executable chmod 755
5. Rebooted router, seems happy.
(I'm sure there are cleverer ways of doing it without rebooting but tailmon was complaining after a tailscale restart from tailmon so I just went Nuclear to save time)
Maybe a good feature to add in the near future would be to build an actual downgrade option into TAILMON, allowing you to specify which version you want it to be running.
Since we discuss downgrading possibilities. Any possibility to enable beta path for Tailscale?
Depending on OS your clients have it's basically just a toggle or application away to enable it. Found it everywhere but for Windows so far.
Definitely a possibility! ;)
Could be handy I guess - I notice tailmon has updated tailscale to 1.86.2 this morning for me anyway so the manual downgrade was a wasted, but interesting, exercise.
Never wasted ... you learnt somefink.
Got a few Beta's floating around out there... why not add ANOTHER one. Right? ;)
What's new!?
v1.2.02b - (TBA)
- MINOR:
Added the ability to DOWNGRADE your Tailscale version to a previous version (even a Beta if you so wish). This certainly is needed functionality, as the Tailscale installer does not have this capability built-in. This procedure was formalized, based on the step-by-step guidance from @ColinTaylor, @rung and @Stephen Harrington.
- MINOR: Implemented an email rate limiter as recently introduced in VPNMON-R3. @JGrana found that in a case of a network outage, that TAILMON will flood you with messages indicating that it tried restarting the service, only to have it loop until network connectivity is restored. This function creates a more formal rate limit on your emails, configured under the Configuration Menu #4, AMTM Email Notifications, and lets you specify how many emails you can receive per hour. An indicator is visible on the top right hand side of the screen, indicating "RL" (in red) as Rate Limiting being disabled, while "RL:10/h" (in green) showing Rate Limiting enabled, with 10 emails/hr set as the rate limit.
- PATCH: Added functionality under the Main Setup & Configuration Menu that allows you to upgrade to the latest Tailscale (B)ETA version. Use at your own risk. You can thank @swejuggalo for this addition! :)
- PATCH: Decided to remove the email notifications for when Operating Modes switch from userspace, to kernel, to custom. Each time the service resets, it applies the settings for these modes, and would shoot off an annoying email about this.
Download link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/TAILMON/develop/tailmon.sh" -o "/jffs/scripts/tailmon.sh" && chmod 755 "/jffs/scripts/tailmon.sh"
Showing the new Downgrade and BETA upgrade options under the Main Setup & Configuration Menu:
Email Rate Limiting options under the AMTM Email Notifications item under the Configuration Menu:
Showing where you will find the Email Rate Limiting indicator on the top left hand side of your screen, this indicating in Green (enabled), at 10 emails / hour.
Enjoy! :)
No issues with the beta. Script automatically downgraded overnight to stable but I updated back to beta again. Suspect the same will happen again tonight but that's okay. AOK either way!
Well, if automatically downgrading to stable it would be a bug. Switching should be a manual step.
