TAILMON TAILMON v1.3.1 -Mar 1, 2026- WireGuard-based Tailscale Installer, Configurator and Monitor (Available in AMTM!)
No issues with the beta. Script automatically downgraded overnight to stable but I updated back to beta again. Suspect the same will happen again tonight but that's okay. AOK either way!
Well, if automatically downgrading to stable it would be a bug. Switching should be a manual step.
@rung Yeah, if you're going to upgrade to the beta, I'd probably advise keeping the autoupdate feature off. Definitely higher risk of something going wrong, so you probably want to manually upgrade that along the way. ;)
The script is unidirectional... if it sees a version in the repository that's different than the one that's currently running, it's going to assume it's newer.
Got bitten by this as well overnight @Viktor Jaep ;)
Something to consider may be separating out the binary and script auto-updates, or just ditching the script auto-updates and letting AMTM update checking system handle the notification?
It goes by build date rather than the number? Trying it out at the moment.
"U(P)date Tailscale Binary to latest version" sees the beta as the newest, right? Without ever suggesting stable build? But auto update, don't?
I don't mind to manually do the updates, as long as I get informed about updates I can go and fetch.
Do you mean the TAILMON script, or the Tailscale binaries?
U(P)date Tailscale Binary to latest version essentially runs "tailscale update" -- it's only going to fetch the most stable version, and may overwrite a Tailscale binary beta that you have installed. That would require a test to see what actually happens.
Update Tailscale to the latest (B)ETA essentially runs "tailscale update --track unstable", so that would update whatever beta you're on to the next newest beta of the Tailscale binaries.
I like the idea of splitting these out. Man, you're always full of great ideas, @Stephen Harrington! :)
Got to keep thinking up things to keep you busy and use up all that spare time you have.
:p
But yeah, it does look like I can figure out if a new beta comes out, and could fire off an email that a new version can be downloaded.
Typing P get me this.
Executing: tailscale update
already running unstable version 1.87.12; no update needed
Restart Tailscale?
[y/n]:
It seems to not think that it needs to install the last stable. But if new stable comes with a different date it might?
That makes me wonder why auto update thinks it needs to update Tailscale, every night (?), with that response with the manual check.
As for the update notice, for the script itself, AMTM can do that. But tailmon need to inform about Tail scale. Best of both worlds. Then I got all I need 🙂
Restart Tailscale?
[y/n]:
Oh that's very interesting. It seems to stay on the unstable track even with that command.
Not sure. Let us know!
I'm using a command: "tailscale version --upstream" to look and see what the latest version is. I wonder if that yields something different for you being on the beta? If the upstream differs from the local version, it forces an upgrade using "tailscale upgrade -yes"
I'll see what I can figure out! ;)
I agree, I think that keeps it simpler and more consistent with other AMTM scripts including the collective *MONs, to just do auto-update on the TS binary if user desires to configure it that way, but let AMTM advise if there is an update available for the script itself (for the usual manual update)?
Here's another beta to try out...
What's new?
v1.2.03b - (TBA)
- PATCH:
Going with recommendations from @Stephen Harrington, the ability to split out to check for updates between the script itself and the tailscale binaries has been completed. These options are set within the same "schedule autoupdate" item under the configuration menu.
Download Link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/TAILMON/develop/tailmon.sh" -o "/jffs/scripts/tailmon.sh" && chmod 755 "/jffs/scripts/tailmon.sh"
Significant Screenshots:
Showing you can split out script and tailscale updates using the Autoupdate Scheduler item under the config.
swejuggalo@RT-BE88U-F1B8:/tmp/home/root# tailscale version --upstream
1.87.12
track: unstable (dev); frequent updates and bugs are likely
tailscale commit: 4df02bbb486d07b0ad23f59c4cb3675ab691e79b
long version: 1.87.12-t4df02bbb4-g97f443f91
other commit: 97f443f91e2a12545b11f73aeb935e9e42a5fb17
go version: go1.24.4
upstream: 1.87.12
What's new?
v1.2.03b - (TBA)
Not taking away from the incredible flexibility added in by @Viktor Jaep with this update but out of interest (anyone) what use case / issues are envisaged whereby the binary only gets updated but not the script; amd indeed the reverse scenario? Do any other scripts have both of these animals?
Has there been instances where a binary update caused issues with a new script (that was updated simultaneously i.e. on the same schedule? Thanks 🙏.
I’ll probably let mine update at the same time, automatically, as my setup is pretty simple, but I’d be interested in those potentially problematic scenarios in case I delve into something less mainstream.
My use case was to stay with the beta script but still update the binary if one comes out. Also, there may be a future time where the updated script is having trouble with my setup, so I want to keep the old version until it gets fixed.
Use case may be beta. Testing. Choosing when you migrate to next version (both stable and beta users may want to do so) and so on.
Wanting to automatically update the script that manage Tailscale that does not necessarily affect Tailscale itself, unless you use certain parts of the script. Likewise wanting to update Tailscale automatically isn't necessarily a problem if you prefer to verify that the script preforms well before leaving it unmonitored.
Thanks to you both. I’ve run betas but never really long enough to experience a cron job updating something while running it, but I absolutely get the reasons, totally understandable. Thanks 🙏
Manual updates running fine (not choosing the beta update)
This will update Tailscale from 1.87.12 to 1.87.33. Continue? [y/n]
Assuming that's expected behavior @swejuggalo?
