The system is automatically deleting traffic statistics records
littlepopkaka
I noticed the traffic statistics data is gone and, after checking the logs, found that it deleted itself. Is it possible to modify the system to prevent it from automatically deleting these records?
Aug 12 01:00:05 BWDPI: [BWANA] Revert process (pid=19859)
Aug 12 01:00:05 BWDPI: [sql_remove_journal(74)] remove /jffs/.sys/TrafficAnalyzer/TrafficAnalyzer.db-journal
Aug 12 01:00:05 BWDPI: [BWANA] remove /jffs/.sys/TrafficAnalyzer/TrafficAnalyzer.db
This issue isn't new, it was reported multiple times for different router models. Comes from TrendMicro engine, nothing you can do to fix. Has to be fixed by Asus upstream first, then the fix will arrive to Asuswrt-Merlin.
