G'day,
this is my forst post at SNB. Please allow me to thank you for publishing a great website with useful content.
I will soon be starting to completely gut and refurbish a 5-storey house. In the process I want to install a wired high speed network. The network expense is small in comparison to the overall refurbishment so I am not concerned with cost, only with speed. Below is a brief description of the anticipated network and its end usage.
a) The basement will house a "server room" with NAS units, network equipment and physical broadband access
b) The network will have 5 users with individual computers. One user streams realtime financial data 8-10 hours per day. All computers share storage on NAS. All computers are backed up via network. NAS streams HD media to 3-4 media players in property. Surveillance cameras store CCTV footage on NAS.
c) Each floor will have 8 wired Ethernet access points (40 total). In addition there will be 2-5 outdoors access points.
d) I want the physical network to at least support 1GB speed
e) I want the network to be scaleable in the sense that equipment can be changed and upgraded without rebuilding the whole thing.
At this stage I have three questions where your input would be valued.
A. Topology
With ~45 Ethernet access points I can see at least 2 ways of building the network:
(i) Run 45 cables to the basement and buy a 48-port switch
(ii) Have an 8-port switch on each floor and connect each of them to an 16-port switch in the basement (some additional ports for NAS etc).
Comments on benefits/drawbacks of ether solution?
B. Cabling
I have been contemplating four alternatives:
(i) Cat6 1 Gigabit cabling
(ii) Cat6 with optical fibre run in parallell for unknown future needs/use
(iii) Cat6a 10 Gigabit cabling
(in) Cat6a with optical fibre run in parallell for unknown future needs/use
One can of course contemplate combinations, e.g. Cat6a/optical for switch to switch connection and Cat6 for switch to wall socket etc.
Any thoughts on this you could share with me?
C. Outdoors access points
Anything I should be mindful of in relation to outdoors connections? (Will be used for surveillance cameras plus a wireless accesss point in garden).
I would be most grateful for any thoughts you could share with me.
Best regards,
hlofgren
A. Topology
B. Cabling
Best regards,
hlofgren
