Hi all,
I have an AX58U and an AX3000. I had AiMesh set up using stock Asus firmware. I flashed both with Merlin firmware. I had noticed at one point that the node (the AX3000) was not in the AiMesh. I've since hard reset both, tried to load stock ASUS firmware again, and the AiMesh network will not set up. When I flash to stock ASUS firmware, it still has the appearance of the Merlin firmware. What am I doing wrong? I hard reset with power off - hold WPS - turn on - wait for power light to go on, flash, then off - power cycle again.
Thanks for any help
Thanks for any help
