Unable to access internet with private dns
kuki68ster
I am getting an error when trying to acess the internet through asus router (ax86u) with merlin 388.1 installed...
Feb 13 22:25:26 bsd: bsd: Sending act Frame to 16:82:60:35:5f:1d with transition target eth7 ssid 7c:10:c9:e5:b9:6c
Feb 13 22:25:27 bsd: bsd: STA:16:82:60:35:5f:1d no response
Feb 13 22:25:27 bsd: bsd: Sending act Frame to 16:82:60:35:5f:1d with transition target eth7 ssid 7c:10:c9:e5:b9:6c
Feb 13 22:25:28 bsd: bsd: STA:16:82:60:35:5f:1d no response
If i set a private dns (nextdns or controld) in my s23 ultra, the internet in my device gets cut...If i disabled the option in my smartphone, it gets acess to the internet...
I deleted unbound, and diversion, and still the issue remais...
If i acess another wifi, i don't get this issue, so i am 99% sure the problem is with the router...
Any help will be appreciated, thanks...
I would first disable DNS Director for this device and try again. If your phone is using DoT to NextDNS or ControlD - the requests are blocked.
You should try pinging dns.controld.com and dns.nextdns.io and see if you get a response. For Control D specifically you can visit this exact URL: https://dns.controld.com/info
If it doesn't load then the domain or IP address is resolves to is blocked on your network.
Did the trick, after disabling dns director i can acess the internet with nextdns....
Is there a configuration, with the dns director activated, that i can set up my router?
Thanks for the help
Yes, exclude this device from filtering. DNS Director is configurable. I don't have Asuswrt-Merlin running at the moment to show you a screenshot, but it's pretty self-explanatory. Your global filtering is perhaps Router. Add this device with option No Filtering.
