Hello all, i have a Nighthawk X6 R8000 on Merlin, now i had a VPN working before but i no longer have that server where the VPN was, so i got a new one, i got my generated .ovpn file, and i uploaded it, click apply and then connect, and the vpn wont just connect. Wento to the system log which i will paste below. i am new to this and still learning, probably some settings i have to change, but dont know what the system log is telling me. Any help would be appreciated.
Mar 27 15:26:02 rc_service: httpd 593:notify_rc start_vpnclient1
Mar 27 15:26:04 openvpn[19262]: OpenVPN 2.4.3 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Sep 25 2018
Mar 27 15:26:04 openvpn[19262]: library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.08
Mar 27 15:26:04 openvpn[19263]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Mar 27 15:26:04 openvpn[19263]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar 27 15:26:04 openvpn[19263]: TCP/UDP: Preserving recently used remote address: [AF_INET]xx.xx.xxx.xx:1194
Mar 27 15:26:04 openvpn[19263]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Mar 27 15:26:04 openvpn[19263]: UDP link local: (not bound)
Mar 27 15:26:04 openvpn[19263]: UDP link remote: [AF_INET]xx.xx.xxx.xx:1194
Mar 27 15:26:04 openvpn[19263]: TLS: Initial packet from [AF_INET]xx.xx.xxx.xx:1194, sid=05d22c91 c8a6dc23
Mar 27 15:26:04 openvpn[19263]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Mar 27 15:26:04 openvpn[19263]: VERIFY OK: depth=0, CN=idon, O=idon, OU=idon, C=US
Mar 27 15:26:04 openvpn[19263]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Mar 27 15:26:04 openvpn[19263]: [idon] Peer Connection Initiated with [AF_INET]xx.xx.xxx.xx:1194
Mar 27 15:26:05 openvpn[19263]: SENT CONTROL [idon]: 'PUSH_REQUEST' (status=1)
Mar 27 15:26:06 openvpn[19263]: AUTH: Received control message: AUTH_FAILED
Mar 27 15:26:06 openvpn[19263]: SIGTERM[soft,auth-failure] received, process exiting
