What Routers support AiProtection Pro?
Logi
The difference between AiProtection Pro and AiProtection Classic it seems IPS and Internet Activity, I have had both features on all my Routers but it is listed as AiProtection, with no Pro, thanks
You can check the 'Tech Specs' tabs on the respective router product pages. A sample check reveals mentioning of "AiProtection Pro" for GT-AX6000, GT-AXE16000 and GT-BE98 Pro, for example. In the router config settings it is simply called 'AiProtection', at least looking at the GT-AXE16000 config.
I haven't met a router that doesn't have Two Way IPS, which is a Pro requirement
