Puck6T9
So I updated my RT-AX86U to the latest 396.7_2 & now my amazon fire stick won’t connect.
It was connecting fine on the 5ghz band. With WiFi 6 mode enabled, enable 160 mhz, & auto select channel including DFS channels. Now it won’t. I have to turn all of those settings off for the fire stick to connect to the 5ghz band. If those settings are on, the fire stick will see the network & connect for a second. Then disconnects & refuses to see the network again, till I turn 5 ghz off & back on.
it was working fine on 383.5. My question is what changed? Why do I now have to turn those settings off for my fire stick to connect. Only seems to be my fire stick also. My phone & Xbox will connect with wifi 6 enabled.
