Dismiss Notice
Welcome To SNBForums
USB thumb drive GUI problem
Discussion in 'Asuswrt-Merlin' started by jlsenter1, Nov 15, 2012.
  1. jlsenter1
    jlsenter1 Occasional Visitor
    Sep 3, 2012
    11
    Currently running 3.0.0.4.246.20 on RT-AC66u. Running a 2gb and 8gb thumb drive on USB. Takes two power cycles for drives to mount. After mounting, Network Map shows both drives mounted. After a period of time, the 2gb GUI shows no device yet the drive is functional. I have seen this behavior on the past 4 releases.
    Regards,
  2. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    18,638
    Canada
    Check the System Log for further details as to what is actually happening. It's possible that you have filesystem corruption preventing the disks from being mounted properly. Also, some USB drives come with a special hidden partition that can cause issues (such as those old U3-labeled drives).
  3. jlsenter1
    Sep 3, 2012
    11
    No log info
    Checked the logs. Nothing associated with drives / mounting. Drive does not have hidden partition. Will re-format drive.
    Regards,
Share This Page
