Hi, I have an RT- AX88U with Merlin firmware, dual wan setup with an LTE modem from Bell Canada:
I just got upgraded to Bell Fibe 1.5 Gbps with Home Hub 4000, so I switched on the option to have the WAN aggregation between WAN and LAN4 ports, sadly the moment I enable the wan aggregation the DUAL WAN setup (on LAN 3 port) gets disabled.
This behavior is stated on asus website https://www.asus.com/my/support/FAQ/1039053/
"2. Dual WAN and WAN Aggregation cannot be enabled at the same time. If you have enabled one of these functions, the other will be disabled automatically."
I was wondering if there is a way around this, some script or command to force it, I'd like to have both options on. The LTE is a failover in case the aggregated WAN fails.
Thank you in advance for your help.
