Interesting. So, maybe it accepts invalid/unrecognized regions, but not an empty one.can confirm that value was blank until I set it today.
Thank you, that will provide me with some test cases to try out.
Thank you for the additional info.Thanks for peeking at this, knowing you have a really busy "dance-card" for us on the Add-Ons. To answer your questions from my experiences.
1. When you go to the UnBound GUI, no error messages. Just get this blank looking panel view, as attached.
2. Click on 'Update Stats', no changes. 'Toggle Lines' or 'Toggle Fill' then data, as attached.
3. On Firefox, you can't select any of the Router GUI options once in Unbound GUI. Have to use Firefox Browser reverse to get back to selectable tabs/options.
When you open the UnBound GUI.
Pressing Toggle Fill...
Your current Unbound Stats WebUI version is 1.4.1, which is rather old (from 2021).Using..."/jffs/addons/unbound/unbound_stats.sh help"...my GUI code level is v1.4.1.
curl -LSs --retry 3 --retry-delay 5 --retry-connrefused \
https://raw.githubusercontent.com/juched78/Unbound-Asuswrt-Merlin/master/unbound_stats.sh \
-o /jffs/addons/unbound/unbound_stats.sh && chmod 755 /jffs/addons/unbound/unbound_stats.sh && \
/jffs/addons/unbound/unbound_stats.sh install
/jffs/addons/unbound/unbound_stats.sh develop
/jffs/addons/unbound/unbound_stats.sh stable
Thanks for the easy to follow details.Thank you for the additional info.
First, you need to install the very latest production 1.4.3 version using the following commands on an SSH terminal window:
Bash:curl -LSs --retry 3 --retry-delay 5 --retry-connrefused \ https://raw.githubusercontent.com/juched78/Unbound-Asuswrt-Merlin/master/unbound_stats.sh \ -o /jffs/addons/unbound/unbound_stats.sh && chmod 755 /jffs/addons/unbound/unbound_stats.sh && \ /jffs/addons/unbound/unbound_stats.sh install
Once you have installed the latest production version, you can immediately switch to the most recent 'develop' branch 1.4.4 version with the following command:
View attachment 68589Bash:/jffs/addons/unbound/unbound_stats.sh develop
If you wish to go back to the master/production version:
Bash:/jffs/addons/unbound/unbound_stats.sh stable
Welcome To SNBForums
