aircoreboy
Over the last couple of months, my 5GHz wifi has become practically unusable with an 80 MHz channel width (to achieve full speed on the ac bridge in the bedroom) which I have recently discovered is because of interference from the Wii U gamepad which uses the four lower channels of the 5GHz band that are obviously all in use since the 80MHz channel width covers all four of the lower bands. This is not good since 5GHz devices are going to become more numerous and on what I assume is a non-DFS supported router, the AC66U, I have no access to channels higher up the band since in the UK and I assume the rest of Europe, all channels above 48 require DFS, rendering my ac network unusable and basically reducing my AC66 to an N66. I have also recently discovered that the standard for implementing DFS and TPC is 802.11h which the AC66U does make use of on the 5GHz band, at least with Rmerlin firmware, and this left me with a few questions,
1. Why implement 802.11h regulation mode on 5GHz when the AC66U can only access the four non-DFS channels?,
2. If 802.11h is properly implemented, why are channels above 48 not accessable?,
3. Is 802.11h properly implemented?,
4. If 802.11h is not properly implemented, could this be having an effect on the four lower 5GHz channels?,
5. If 802.11d+h is being used, then as per the 802.11d standard, the router should advertise what jurisdiction it is operating in (removing the need for manufacturers to release jurisdiction specific models) and with 802.11h, offer access to all available channels within advertised jurisdiction, why is this not happening? (incidentally, "As of January 1st, 2015, the U.S. FCC banned the use of 802.11d within the U.S.", it would be interesting to see if USA users had access to regulation mode 802.11d)
Ref: http://en.wikipedia.org/wiki/IEEE_802.11h-2003
Ref: https://docs.google.com/file/d/0ByA6tWZXOSXuZThyOUxVY2UxZmM/edit?pli=1
Ref: http://www.digitalairwireless.com/wireless-blog/t-5ghz/quick-guide-to-5ghz-uk-part-1.html
Ref: http://www.digitalairwireless.com/wireless-blog/t-5ghz/quick-guide-to-5ghz-uk-part-2.html
Ref: http://en.wikipedia.org/wiki/IEEE_802.11d-2001
