ChannelHog - Monitor And Force Maximum 5GHz Bandwidth
Adamm
Part of the Furniture
v1.1.1
Updated - 28th June 2022
ChannelHog - Monitor and force maximum 5GHz bandwidth
About;
Tired of badly configured neighbours and DFS cutting your wireless bandwidth in half? Then this is the script for you!
ChannelHog will monitor your current 5GHz channel bandwidth on a daily basis and if it detects anything lower then 160MHz it will restart the 5Ghz radio. This script also includes optional Discord notification support.
Note: Your clients will temporarily be disconnected from the 5GHz band in the event of a restart, this usally takes 1-2 minutes and occurs at 4.45am.
This script will always be open source and free to use, but if you want to support future development you can do so by Donating With PayPal.
Usage;
To open the menu its as simple as;
sh /jffs/addons/channelhog/channelhog.sh
Installation;
In your favorite SSH Client;
mkdir -p /jffs/addons/channelhog && /usr/sbin/curl -s "https://raw.githubusercontent.com/Adamm00/ChannelHog/master/channelhog.sh" -o "/jffs/addons/channelhog/channelhog.sh" && chmod 755 /jffs/addons/channelhog/channelhog.sh && sh /jffs/addons/channelhog/channelhog.sh install
Reserved
@Adamm What do I use for a Discord URL? Do I need it?
UPDATED 11/01/2020
ChannelHog.svg
ChannelHog - Monitor and force maximum 5GHz bandwidth for the AX88U
About;
Usage;
Installation;
I guess I don't get the webhook part. never heard of it and don't know what or how to get the URL needed.
Its for optional Discord notifications, if you don't need this feature you can happily ignore it.
Thanks brother @Adamm looks good changed my Chromecast to 2(AC)80 from 2(AC)40. Cool! :D
what are the chances this will get ported over to the ac86?
I can't remember if devices with 80MHz channel width suffer from degradation on the 5GHz band (my spare devices are all out on loan to family members), but if they do I can fairly easily adapt the script for them.
Also, does this work for an AiMesh setup?
I don't see any reason why it wouldn't.
I have a small issue:
Select Menu Option:
[1]  --> Start ChannelHog
[2]  --> Check Channel Bandwidth
[3]  --> Temporarily Disable ChannelHog
[4]  --> Update ChannelHog
[5]  --> Install ChannelHog
[6]  --> Uninstall
[e]  --> Exit Menu
[1-6]: 2
/jffs/addons/channelhog/channelhog.sh: .: line 341: can't open '/jffs/addons/channelhog/channelhog.cfg'
What should I do bud?
Select Menu Option:
[6]  --> Uninstall
[e]  --> Exit Menu
[1-6]: 2
Did you complete the installation first? That should create the config file.
Actually when selecting 2 it kicks me out after saying 2 is not an option. If i run the command
sh /jffs/addons/channelhog/channelhog.sh check
The command works.
Can you show me the exact output? Seems to be working on my end (no output means everything is running fine, I added some filler text in a patch)
#                          Monitor And Force Maximum 5GHz Bandwidth For Asus Routers                       #
#                                  By Adamm - https://github.com/Adamm00                                   #
#                                           11/01/2019 - v1.0.0                                            #
Select Menu Option:
[6]  --> Uninstall
[e]  --> Exit Menu
[1-6]: 2
ChannelHog: 80MHz Channel Width Detected - Restarting Wireless Service
This may be normal eh?
Select Menu Option:
[6]  --> Uninstall
[e]  --> Exit Menu
[1-6]: 2
My channel bandwidth is actually set to 160. Should I lower it?
Your channel width should be set to 160MHz and ideally a fixed channel;
Ok I mirrored your settings and then clicked "Apply," but had to reinstall channelhog to get it to work again.
It work with all channels enabled too:
I first set it to 160MHz and then started channel hog, after that I switched over to 20/40/80/160 MHZ and checked channel bandwith. Now it's on 160MHz.
I have same settings and this happens.
Select Menu Option:
[6]  --> Uninstall
[e]  --> Exit Menu
[1-6]: 2
Every single time.
