I am trying to connect my Dell Axim X51v running Windows Mobile 6.1 to the RT-N66u. This is a 802.11b device. This device is rarely used so I am not willing to slow my 2.4GHz network down when it is not in use. I have set it to WPA personal automatic and the encryption to TKIP/AES. So if only modern N 2.4GHz clients connect, I will be able to run them at full speed. If the Dell comes in the router is supposed to accommodate it and might slow down the network which is okay. Problem is: I cannot connect the Dell Axim with these settings. I can connect when I set the 2.4GHz network to open system (no security). I am not willing to use WEP only WPA/TKIP, which this Dell supports. My previous router was a DIR-825, similarly set up to auto TKIP/AES, which the dell could connect to.
Any suggestions? Do the WMM and key rotation matter?
