AB-Solution - The Ad Blocking Solution
Here you go =)
Cron:
Cron job(s) info:
AB-Solution sets these cron jobs when service is on:
AB_UpdateHosts: a is on, updates blocking file, weekly
AB_RotateLogs: l is on, rotates log files, daily
AB_WeeklyStats: rs is on, sends stats, weekly
AB_AutoBackup: bu is on, sends backup files
AB_ABupdateNotify: un is on, checks for AB-Solution updates
The following cron jobs are set (cru l):
ls: /tmp/var/spool/cron/crontabs: No such file or directory
(there are no cron jobs set at the moment)
That's NOT good.
How about listing them directly in the terminal:
cru l
(lower case L)
cru l
00 3 * * Fri /tmp/mnt/Asus/adblocking/addon/update-hosts.add cronjob #AB_UpdateH osts#
25 2 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware#
25 1 * * Mon sh /jffs/scripts/firewall update #Skynet_autoupdate#
0 * * * * sh /jffs/scripts/firewall save #Skynet_save#
cru l
That's better, do you have logging disabled in AB?
Yes, if i enable and get dnsmasq error router will be unresponsive untill i pull the usb and restart. (log will become several GB in size.)
No problem.
Two more things of interest to me, output of:
find / -name crontabs
And if you go into the location when found, is there a file in it with your router username in the crontabs directory?
Sure thing =)
Yes, the file exists.
OK, thanks. That differs from 380.x which is /tmp/var/spool/cron/crontabs/
Sure thing =)
What about dnsmasq version?
dnsmasq -v
Dnsmasq version 2.78 Copyright (c) 2000-2017 Simon Kelley
Compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset no-auth DNSSEC no-ID loop-detect no-inotify
The only difference is the no-ID compile option which I cant find in the Dnsmasq documentation.
Sure thing =)
Another test, just verifying it's not the pipe I use for the cj function:
cru l | sed -e 's/^/ /'
This should indent the cron jobs by one character.
00 3 * * Fri /tmp/mnt/Asus/adblocking/addon/update-hosts.add cronjob #AB_UpdateHosts#
Alright, got that nailed down.
The cron errors should be gone in 382.x and the cj function will properly display them.
I'm waiting for a reply by Merlin concerning the Dnsmasq errors.
Depending on his findings I can push an update for AB-Solution.
@.TT. can you run 22 in the AB UI , then scroll up and post the complete "checking AB-Solution installation".
And then in the sub menu the rc function, also posting the output.
22
checking /jffs/scripts/dnsmasq.postconf
jffs file check, passed:
file found
content looks good
checking /jffs/scripts/post-mount
file found
content looks good
checking ab_dnsmasq_postconf.sh
file found
content looks good
checking white and black list
files found, no further checks
checking blocking_file
file found
content looks good
checking ab-solution.cfg
file found
content looks good
checking update-hosts.add
file found
content looks good
checking rotate-logs.add
file found
content looks good
checking cron job blocking file update
grep: /tmp/var/spool/cron/crontabs/admintomas: No such file or directory
checking symlink state
file found
content looks good
checking shell history state
file found
content looks good
checking /etc/dnsmasq.conf
file found
adblocking state looks good
Router check RT-AC86U @ 192.168.2.1
checking internet access with Level 3 DNS
(209.244.0.3)
Level 3 responded, Internet access OK
checking Administration/Operation Mode:
Router is in Wireless Router mode
checking /jffs, Administration/System/
Persistent JFFS2 partition:
- Enable JFFS custom scripts and configs:
Custom scripts are enabled
- Format JFFS partition at next boot:
No /jffs/ formatting is scheduled
- read/write capability to /jffs:
Device /jffs/scripts test passed
checking AiProtection/Network Protection:
Network Protection is disabled
(even when enabled, this has no impact on
AB-Solution functionality)
checking AiProtection/Parental Controls:
Parental Controls is disabled
checking AiProtection/DNS Filtering:
DNS-based Filtering is enabled
Depending on your settings, AB-Solution may
not work for devices in the Filter list
checking LAN/DHCP Server,
Enable the DHCP Server:
DHCP Server enabled
DNS Server 1 and DNS Server 2:
Both LAN-DNS Server fields are empty
Forward local domain queries to upstream DNS:
Forward to upstream DNS disabled
checking AiCloud/Settings,
AiCloud Web access port:
(only relevant when pixelserv-tls is installed)
AiCloud not in use or port not set to 443
checking USB Application/Download Master,
(only relevant when Entware and
Download Master is not installed
checking read/write capability to
/tmp/mnt/Asus:
Device /tmp/mnt/Asus test passed
checking for device label for
/tmp/mnt/Asus:
Device has a label and is not named by system
checking for other scripts,
they may add additional log file entries:
no redirects found
checking for common other scripts in use,
they may block additional domains or IP's:
These scripts were detected:
Be aware they block IP addresses and domains
outside of the control of AB-Solution
AB-Solution has built in procedures to work well with
detected scripts and may auto exchange lists with them
NOTE checking AiProtection/Network Protection is incorrect.
"AIProtection - Two-Way IPS" is on
"AIProtection - Infected Device Prevention and Blocking" is on
(209.244.0.3)
DHCP Server enabled
/tmp/mnt/Asus:
/tmp/mnt/Asus:
no redirects found
AiProtection/DNS Filtering is set to on on your router, for AiProtection/Network Protection I check these values:
nvram get wrs_cc_enable
nvram get wrs_mals_enable
nvram get wrs_vp_enable
If one of them is set to 1 then I see it as enabled.
I have:
nvram get wrs_cc_enable 1
nvram get wrs_mals_enable 0
nvram get wrs_vp_enable 1
I have:
OK, that is a coding error, thanks for reporting.
