AC86U hanging with 386.5 after upgrade from 386.4
pfonseca
Since last week that I've upgraded my AC86U from 386.4 to 386.5, it randomly hangs loosing internet connection. When I look at logs I don't see nothing relevant.
Should I configure logs in a particular way to try to find what could be the issue? If this persists, I'm going to downgrade to 386.4 or do you have a better approach?
Regards,
What else is running on this router? Do you run any custom scripts on it?
The same things I run from years now. Some init scripts to firewall, dnsmasq and start some services from entware, this two in fact:
2751 matador 21544 S nginx: master process nginx
2752 nobody 21776 S nginx: worker process
2767 matador 6564 S shellinaboxd -t -u xxxxxxx --css /opt/lib/shellinabox/white-on-black.css -b --localhost-only
2768 matador 6564 S shellinaboxd -t -u xxxxxxx --css /opt/lib/shellinabox/white-on-black.css -b --localhost-only
All packages installed are updated.
Regards,
I think I found the issue. I've enabled IPV6 after the upgrade. When I disabled it, the issue disappears.
I hope this can help.
Regards,
