AC86U - USB Share not visible in Win 10 Explorer
sl4fko
A problem, that just appeared out of nowhere...
A disk formated in EXT4 (one partition) used for SWAP and Transmission is connected to my AC86U, firmware is latest beta 384.15_beta1.
In file explorer in Win10 I can ONLY see "entware" folder, there is no "Torrent" folder (Transmission was installed using default guide here (still works, torrents can be downloaded): https://github.com/RMerl/asuswrt-merlin/wiki/Installing-Transmission-through-Entware )
What gives? Samba is enabled and properly configured, tried SMBv1, v2, v1+2. In shares under these settings all folders are visible (Torrent also...)
It is not a Windows fault, I also can not "see" the folder on the phone file explorer (entware folder is there, same view as on computer...)
So...
Help please? :D
I've noticed this behaviour too with AC86U. I can view the Samba shares via MacOS & Android, but Windows 10 fails to see the shares. I'm on 384.14_2 stable release.
Are you talking about the same problem? Specifically an issue with only the "Transmission" share. It sounds more like you're talking about the "normal" Windows 10 issue.
