[AC87U]: Limit Bandwidth On 5GHz Band Using Script
dzg7pl
Hi everybody,
I'm trying to write a script that does the following:
  • Read a list of user/device name/mac addresses/limit
  • Check if the device is active (i.e. bandwidth is over a given threshold) - e.g. every minute
  • Count the times the device is over this threshold
  • If the device breaches the LIMIT read in for that MAC, then limit the up/down bandwidth for that device.
I have got all this working for eth1 (2.4GHz) using the tc command. However, I am unable to use tc for wifi0 - tc reports it cannot find the device.
The code I am using to limit the bandwidth is as follows:
tc qdisc add dev $IF root handle 1: htb default 30
tc class add dev $IF parent 1: classid 1:1 htb rate $DNLD
tc class add dev $IF parent 1: classid 1:2 htb rate $UPLD
U32="tc filter add dev $IF protocol ip parent 1:0 prio 1 u32"
$U32 match ip dst $IP/32 flowid 1:1
$U32 match ip src $IP/32 flowid 1:2
Can anyone help?
Cheers
Tim
Probably impossible on the 87U, the 5ghz chip is totally separate to the rest of the system
Just thinking about this though - how does the UI manage to do this then? Surely if it can be achieved by the UI, there must be a way to do this, mustn't there?
i think you'd need to dig in to communicating with the quantenna chip
Yeah, I've been looking into the qcsapi_sockrpc command and its miriad of options, but none of the wifi related ones appear to fit the bill. I've also enabled telnet on the Quantenna chip and had a play with tc on there, but the only interface that is recognised is eth1_0, but that doesn't allow me to run the commands I've set out above! Argh!
Ok, think I've got it - iptables appears to work:
modprobe -a xt_hashlimit.ko
iptables -N RATE_LIMIT
iptables -I FORWARD 1 -p ALL -m mac --mac-source $MAC -j RATE_LIMIT
iptables -A RATE_LIMIT_$USER -m hashlimit --hashlimit-above 1kb/s --hashlimit-burst 1kb --hashlimit-mode srcip,dstip --hashlimit-name bwlimit -j DROP
Appears to work across both bands - hurrah! More testing required though.
