Aimesh local networking
willkho
Hi all,
Need a help here.
I just setup an aimesh. Everything is working perfectly fine.
Router downstair, the node upstair.
2 desktop Pc are connected to the router downstair, one via cable and one via wireless and a laptop is connected the node up stair.
all computer can see each other but the wireless one can't access the other computer that connected through wireless. error code: 0x80070035
The one on cable can be accessed from anywhere.
however, if I turned of the node or the main router, forcing both wireless connected to the same device then they can access each other.
Local network and internet is equally important since I sometimes work from laptop.
Is this a bug from aimesh? Any of you experience this?
many thanks in advance.
Really sorry for that.
The router is RT-AC86U (firmware: 3.0.0.4.384_32797-g907bbdf) and the node is RT-AC68U (firmware: 3.0.0.4.384_32797-g907bbdf).
Thanks again.
Did you factory default reset after upgrading to the latest firmware?
Did you reboot all clients after building the new network? And remap any logical network drives in Windows?
OE
