AiMesh Setup Review/Assistance Please
pvp
Hi all,
Firstly, appreciate all the information & knowledge shared on this forum. I've been on a bit of a journey in search of better wifi coverage around the house and ended up buying a RT-AC86U (and then weeks later adding a second one). I'm hoping a few folks can look at my info and logs and let me know if there is room for improvement.
I've done a bunch of reading on this forum and others when I was trying to resolve my coverage issues with my previous Linksys e4200 router. Once I got the RT-AC86U router, I followed OzarkEdge's AiMesh install notes (using firmware 3.0.0.4.384_21140 - as it seemed most stable at the time).
The single 86U was a marked improvement over the E4200 and where I previously lost wifi in the upstairs bedroom, I now had decent wifi signal (my cell didn't drop to LTE anymore and I could stream video without a lot of buffering). This one 86U seemed enough to provide decent coverage upstairs, but using WiFi Analyzer I could see the signal level was around -50 to -60 db.
Given the success with the first unit, I got a second 86U unit. Following OzarkEdge's notes, I factory reset both units, updated the firmware to 3.0.0.4.384.45149 and setup the AiMesh. Things started out just OK, but went downhill rather quickly, my cell was dropping to LTE (no wifi) again and browsing speed overall for all clients was notably slow. I also noticed 2.4G band was dropping every few moments. (Note, the configuration was mostly default, smart connect & roam assist enabled, upnp disabled).
After more reading I came to the conclusion that there was perhaps:
  1. too much interference on the 2.4G channel that Smart Connect picked (Ch.1)
  2. maybe upgraded firmware prematurely
  3. maybe my roam assist/node placement is not ideal (too far or collisions?)
So I reset both to factory, downgrade to 21140, setup AiMesh again, but this time turn off Smart Connect and manually select Ch 6 for 2.4G @ 20Mhz and Ch 40 for 5G @ 20/40/80 for max compatibility. Roam Assist is enabled, but I set the threshold to -70 db for both bands.
Browsing speed seems to be OK, speed tests are OK (not stellar). My cell doesn't drop to LTE in the bedroom; getting WiFi at seemingly full bars.
I reviewed my environment using wifi analyzer, inssider, and the Asus system log and I'm reaching my limit in understanding the various MAC addresses that show up (I'm guessing the routers create one for 2.4G, 5G, KBear_Net (main ssid), KBear_Guest, one for the main router, one for the node???). For example, I see MAC 4C:ED:FB:90:6B:14 which is at the lowest level, but the node MAC is 4C:ED:FB:90:6B:10
Here's some additional info that may help with the attachments:
RT-AC86U ROUTER:
LAN MAC Address: 0C:9D:92:2D:01:50
2.4 GHz Address: 0C:9D:92:2D:01:50
5.0 GHz Address: 0C:9D:92:2D:01:54
RT-AC86U NODE:
MAC Address: 4C:ED:FB:90:6B:10
So at the end of this I'm hoping a few folks could take a look at the info and let me know if there is room for improvement (or anything else I can provide that would help you help me).... Thanks in advance!
scan.png = overview of wifi environment (my network SSID is KBear_*)
scan_24G.png = signal levels on 2.4GHz
scan_5G.png = signal levels on 5GHz
inssider_11Jan2019.png = overview of wifi environment using Insidder
syslog.txt = Asus router system log file
  • syslog.txt
OzarkEdge
Part of the Furniture
Hi all,
RT-AC86U ROUTER:
RT-AC86U NODE:
View attachment 15835 View attachment 15836 View attachment 15837 View attachment 15838
Are you resetting after uploading the firmware?
Me, I would reset both routers, cycle power, load 45149 on the first router that was working ok, perform a GUI Restore/Initialize, and configure it per my notes except avoid the Trend Micro stuff for now... Administration\Privacy\Withdraw.
Use that newish router for a day or so to observe it.
If all is good, repeat for the second router including GUI Restore/Initialize after installing 45149. Then add it as the node to form the AiMesh.
Then give the system a few days to settle in before making critical observations... it seems to improve with time. This is not to say that obvious faults are not real issues.
Make sure your first router is still the root node/router, since it was working well standalone. The newest router may have an out-of-box issue so you want to keep an eye on it.
OE
pvp
Thanks for the quick reply. Actually, I don't believe I did the GUI Restore/Initialize after the firmware update.
I re-did the setup with the initial router and am monitoring it. I did have to turn off Smart Connect as it wanted to choose Ch. 1 and then Ch. 3 and they weren't good choices for my environment. Other than that, everything configured per your notes and will monitor before adding the node.
OzarkEdge
A reset needs to be performed after a significant firmware change, and always with AiMesh rolling development until we feel confident otherwise, imo.
If you use a single SSID for both bands, I would stick with Smart Connect for node band steering and give it a chance to settle on workable channels and prove itself. Then if needed later on, reboot the router to encourage it to move to another channel. This approach might work for you.
OE
