It's no longer experimental since the release of OpenVPN 2.6.0 a few months ago.No... it's still experimental...
I was thinking of trying it in pfsense as it allows OpenVPN to leverage Intel’s QAT.
You don`t need to be mainlined in the linux kernel to be considered "not experimental". Plenty of device drivers aren't mainlined yet they are still considered "stable" by their developers. And also there are things that are mainlined and yet carry the EXPERIMENTAL kconfig flag.It's still in net-next over in kernel land...
So when can we expect it to be merged into AsusWRT-RMerlin?
Kernel 5.2+ is required.So when can we expect it to be merged into AsusWRT-RMerlin?
Already did, long ago. Requires a newer kernel than what the newest SDK uses.And while you're at it - might consider ksmbd - smb3 support as a kernel module
OP never said he wanted to use it with an Asuswrt router, he simply asked in general if anyone had been using it.Which goes back to my original point about OPVN-DCO...
No... not supported
It depends on where the bottleneck is. If the bottleneck is the CPU, then DCO will help get higher throughput. But if the bottleneck is your WAN link, then DCO might only help in reduce CPU usage.so far I didn't see much difference.
Welcome To SNBForums
