VPN for travel - NordVPN or using my USG100 Flex?
nikleb
I need a VPN solution while traveling abroad. E.g. for entertainment services.
I gather I coudl subscribe to NordVPN or similar.
On the other hand I have a USG100 Flex. Coudl I use the Zyxel device for the same purpose?
If this device has VPN Server option - set it up, connect to your home network, use your home ISP to access what you usually access.
Also, will my ISP (comcast) be good with this?
Your ISP doesn't care much what you use your Internet connection for unless it's not something illegal or restricted by the contract.
