So I have a Asus GT-AX11000 router as my main router. I had a dead spot in one of the bed rooms for wifi so I ran an ethernet cable to this room and setup an old RT-AC68U as a node for aimesh. Worked great for the last few months, then suddenly the wifi strength on the node dropped from 200mbs download to about 10-20mbs.
Both routers have updated firmware and I've tried rolling them back (firmware was the same when problem started)
The node is hard wired to the main router so there is no wireless backhauling. I tried manually setting ethernet backhauling with no luck. Router settings say it is using the ethernet connection. Connection quality to node says "Great."
I used another router I had laying around, a RT-AC86U and I am having the same exact problem.
Tried multiple reboots.
If I am in the main living area (where main router is) I get about 500mpbs download on wifi.
If I have my device, 2inches from the node, I get 300mpbs (normal). If I am 3ft from node, I get about 100mpbs. 10ft from node is about 10-20mpbs.
I would imagine it has to do with signals and certain bands overlapping, idk. I have no idea where to go from here.
