Asus AX88U Client VPN, custom configuration too short
Andr34g
Hi all,
I'm trying to configurate an OpenVPN with NordVPN on my Asus AX88U Merlin 386.8.
I need to fill in 495 lines of code inside custom configuration but it's impossible because is very short.
I loaded also a ovpn file with all configuration but result is same.
I'm trying to add a configuration with 495 routes because inside Route of Asus there is a limit of 64.
Do you know if is there a way to solve this issue or to add more custom configuration to same openvpn ?
Welcome to the forums @Andr34g.
There is no way around those limitations (there is limited, finite storage space).
Your best bet would be with some sort of Pi setup.
