1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Asus gt-ac5300 gpl source Compilation
Discussion in 'ASUS AC Routers & Adapters' started by stevef9432203, Dec 29, 2017.
  1. stevef9432203
    stevef9432203 Regular Contributor
    May 10, 2015
    64
    Have any of the local Uber-Geeks managed to get the gt-ac5300 source code to compile???? So far all efforts on my part
    have failed badly. The cross toolchain directories appear totally absent. Sigh. I want add a few service feature(s)
    but till I can build the damn image am in Snafu mode.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    26,927
    Canada
  4. sfx2000
    sfx2000 Part of the Furniture
    Aug 11, 2011
    12,387
    San Diego, CA
    Review RMerlin's git-hub...
    The toolchain and paths are a bit odd, but they work for the most part - never played with gt-ac5300, and it's a bit of an odd duck in any event.
  5. stevef9432203
    May 10, 2015
    64
    Very Nice in some ways, but opt ware or entware seem to be not useable
    Sent from my SAMSUNG-SM-T677A using Tapatalk
  6. stevef9432203
    May 10, 2015
    64
    Anybody been able to build any of the GPL gt-ac5300 source builds. Has been damn frustrating. Building Merlin code works, ac5300 is ok. GT seems basically broken.
  7. Odkrys
    Odkrys Senior Member
    Jul 28, 2016
    214
    Digital Ocean Ubuntu 16.04.4 64bit.
    dpkg --add-architecture i386
    apt-get update
    apt-get install libncurses5 libncurses5-dev m4 bison gawk flex \
    g++-4.7 g++ gengetopt git gitk zlib1g-dev autoconf autopoint \
    libtool shtool autogen mtd-utils intltool sharutils libstdc++5 texinfo \
    dos2unix xsltproc u-boot-tools device-tree-compiler python qemu \
    gperf liblzo2-dev uuid-dev build-essential lzma-dev liblzma-dev \
    lzma binutils-dev patch cmake intltool libglib2.0-dev gtk-doc-tools \
    libc6-i386 lib32stdc++6 lib32z1 libelf1:i386 libncurses5:i386 libc6-dev-i386 \
    bc libtool-bin gnulib xutils-dev libltdl-dev unzip
    useradd -d /USER -m -s /bin/bash USER
    passwd USER
    nano /etc/sudoers
    # Allow members of group sudo to execute any command
    %sudo ALL=(ALL:ALL) ALL
    USER ALL=(ALL) ALL
    chmod u-w /etc/sudoers
    su - USER
    wget http://dlcdnet.asus.com/pub/ASUS/wireless/GT-AC5300/GPL_GT_AC5300_300438420648.zip
    unzip GPL_GT_AC5300_300438420648.zip
    tar -xvzf GPL_GT-AC5300_3.0.0.4.384.20648-g21e3702.tgz
    cd
    git clone https://github.com/RMerl/am-toolchains.git
    sudo dpkg-reconfigure dash
    -> No
    sudo ln -s ~/am-toolchains/brcm-arm-hnd /opt/toolchains
    echo "export LD_LIBRARY_PATH=$LD_LIBRARY:/opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/lib" >> ~/.profile
    echo "export TOOLCHAIN_BASE=/opt/toolchains" >> ~/.profile
    echo "PATH=\$PATH:/opt/toolchains/crosstools-arm-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin" >> ~/.profile
    echo "PATH=\$PATH:/opt/toolchains/crosstools-aarch64-gcc-5.3-linux-4.1-glibc-2.22-binutils-2.25/usr/bin" >> ~/.profile
    cd ~/asuswrt/release/src-rt-5.02hnd
    make gt-ac5300
  8. stevef9432203
    May 10, 2015
    64
    Thank you,
    will spin up a VM with and shoot at it one more time
  9. stevef9432203
    May 10, 2015
    64
    Got a lot further, build completed, files have same names.
    Router does not load the image, no errors
  10. stevef9432203
    May 10, 2015
    64
    Any suggestions?
  11. Emanuele_Bro
    Emanuele_Bro New Around Here
    Monday
    2
    Hi to all, i'm also interested to compile sources of the ASUS rog gt-ac5300, i'm trying to compile with the procedure listed above and I will reply after I reach the firmware compiled; I would know how is possible, after a proper compiled firmware without any errors, that the router doesn't allow you to flash this new firmware. What kind of message does it return to you?
    I would know if i flash a corrupted firmware and I would brik the router if there is a safe recovery procedure to flash again a stock firmware and recover the router from the briked state( how can I get into recovery state(TFTP) on this router?).
    Thanks for the answers, cheers Emanuele
  12. RMerlin
    Apr 14, 2012
    26,927
    Canada
    Recovery mode is identical to other Asus routers - press Reset while turning the router on. Test the procedure before proceeding to firmware flashing just to ensure you can properly enter recovery mode.
    Also for extra safety, use the _ubi.w firmware image, not the cfe_ubi.w image. I'm not 100% sure if the cferom version will overwrite the bootloaders, or only some of its default values.
  13. Emanuele_Bro
    Monday
    2
    Thank you you thousands for the answer i followed so much of your discussions in also other forums you are a guru of crosscompiling :) I would love to add some features to the last firmware and preserve the lovely interface of the rog rapture gt-ac5300...i want to use fq_codel instead sfq as qdisc in the qos script but when I try to attach any fq_codel queue on the root parent htb I always get a an error RTNETLINK no such file or directory and with the modprobe I didn't find that module so I have to install it but I really don' know how cause it is the first time I work on arm crosscompiling, how did you solve the prblem of fq codel in asus Merlin? Thank you in advice:)
  14. stevef9432203
    May 10, 2015
    64
    Well so far I and another gentleman have finally managed to get clean builds of the of the gt-ac5300 rom images. Names match, but the image built by the make file is about 12Mb shorter than the image file on the factory Asus Web page. Sigh. Rom uploader just hangs. His VM of Ubuntu builds in about 6 hrs, mine 7.5 minutes. At a loss here. Any suggestions welcome.
  15. RMerlin
    Apr 14, 2012
    26,927
    Canada
    No idea, since I've never tried to build the GT-AC5300 GPL.
    Building the closest firmware (RT-AC86U) takes me a bit over 20 minutes on my VM running on an i7 7700K.
  16. stevef9432203
    May 10, 2015
    64
    Have you managed to load a gt -ac5300 image file you've built? No Joy here. Builds OK on two different VM machines, but image file about 12 MB TOO SHORT
