Asus RT-AC3200 Dual WAN Load Balancing + Rules + Failover
DolbyAtmos
Hey guys 'n' gals,
I have an Asus RT-AC3200 router and two VDSL lines with their own modem/routers.
I want to manually assign the different VDSL Lines ( let's call them VDSL1 + VDSL2 ) to the various network devices/PCs.
I want Load Balancing with Routing tables in other words.
I have configured it as follows:
Dual WAN Mode: Load Balancing
Ratio: 1 to 9 ( want to offload most devices to the VDSL2 line and keep the VDSL1 to the "core" devices )
I have configured the routing tables ( 28 entries ) to assign the desired VDSL line to each device via IP.
My problem is that whenever one of the two VDSL lines malfunctions, the devices assigned to it doesn't "failback" to the only available line.
Any ideas on how to fix this ?
Running the latest official firmware from Asus.
I have the same issue. Somehow the feature you and I are looking for does not exist.
In other words: load balancing does not do failover. It only does load balancing.
