Asus RT-AC88U NAT Passthrough
hasarouter
In Asus RT-AC88U, the VPN related NAT Passthrough by default allows
PPTP Passthrough
L2TP Passthrough
IPSec Passthrough
RTSP Passthrough
H.323 Passthrough
SIP Passthrough
do any of these pose a security liability ? ie can someone from the WAN take advantage of these passthroughs to connect internally ?
The VPN passthru's are actually an artifact of the old Linksys WRT54G source code - it's outbound only, and most smart devs don't touch things that work ;)
Unfortunately, Asus decided last year to make these settings do "something". Beside loading the NAT helper, disabling it will also generate a firewall rule to drop traffic for that port... That's something I've reverted in my firmware, because this "all or nothing" actually causes problems for people who need the NAT helper disabled BUT still keep the port open.
gah - missed that one, generally it's been a belly button feature in the past - had a useful thing and then kind of a non-issue...
Last time I had to worry about "PPTP passthru" for example was on my WRT54G going into a Win2K host that was running a PPTP host for remote access...
For outbound - one shouldn't really need to be concerned with any of the pre-defined switches, and for inbound, generally port-forwarding to an internal LAN host works...
how can i truly disable these then? so not firewall rule gets created?
I don't know. My firmware allows you disable the NAT helper without actively blocking the port, I don't know if Asus changed that since that was originally discussed, back in 2018.
