Release Asuswrt-Merlin 3004.388.9 is now available
Read previous posts, this has already been discussed multiple times over the past two weeks.
I have looked through the whole thread and I don't see anything about these parts of the webpages not loading. All I see is something about not agree to the new terms.. I already saw that window and did agree to the new terms.
@RMerlin I am confused on what I am missing.. I can't seem to find others talking about missing web elements just that they need to accept the terms which I already did or that things aren't fitting on the page !
@RMerlin I think I have discovered at least my problem.. So with this firmware if I use my afraid DYNDNS hostname to connect to the router those web elements don't load they appear as not found meaning they error out. If I connect to the router with the IP address the elements load fine. I have tried even DuckDNS and it still is not loading the elements using a hostname. If I downgrade the firmware back then those elements load. What has caused this change ?
Asus changed the way that frame gets loaded in the merged GPL. Initial reports seemed to point at this being caused by that decade-old bug in Chrome when dealing with self-signed certificates and https. I have not been able to reproduce the exact issue of that frame failing to load, just the usual random CSS/images failing to load for me.
The fact that you experience it while using the DDNS hostname is an additional piece of data however that I didn't receive from previous reports.
If you look at your browser console, do you see any errors? The HTTPS issue I was suspecting generaly manifests with random "TOO_MANY_RETRIES" errors in the browser console.
@RMerlin I'm going to message you privately because I'm posting my domain here and I don't want to like show everyone that & that seems to be what the issue is. Meaning it seems to be that these changes is causing the firmware to change the domain name which is then causing 404 errors ? I have sent you the full log privately.
Thank you - with your specific test case I was able to reproduce the issue, and track down its source.
For reference, the issue only occurs with specific hostnames, and would result in the web page trying to access a truncated hostname when trying to display that frame. The problem was in the web server itself and not the web page. I have fixed it by correctly resetting that pointer before it gets reused.
Known issues:
  • Custom DDNS cannot be configured on the webui (fixed with this and this commit)
  • Network Map failing to display System Status for some users (truncated hostname provided by web server, fixed with this commit)
Wait 388.9_1 ???
hello i have again this problem : Your router is running low on free JFFS storage, which might affect its stability.
Review the content of the /jffs directory on your router. ,, ..
martin@RT-AX88U:/jffs/.asdbk# ls -l
-rw-rw-rw- 1 martin root 45505024 Feb 22 17:16 main_checker.sh_bk
what the hell size ?? 45mb ? and what is this
Post in thread '/jffs/.asdbk/main_checker.sh_bk growing' https://www.snbforums.com/threads/jffs-asdbk-main_checker-sh_bk-growing.88979/post-893770
is it possible to temporarily delete this file without any problems?
As Dave mentioned in the post I linked too. You should open it first to identify what it is... That will give you your answer.
apparently it's a 'swelling backup of the settings' the file is gigantic for a specific analysis .. I would need to know which script or process is creating this disaster so that I can edit or fix the specific script .. I don't have much time and my router started to crash because of it ,, the file cannot be deleted .. so I will probably have to do a complete factory reset :(
Since the update, about ten days ago, I see this in syslog every few days:
Apr 21 10:13:31 kernel: CPU: 1 PID: 3108 Comm: asd Tainted: P           O    4.1.51 #2
Apr 21 10:13:31 kernel: Hardware name: Broadcom-v8A (DT)
Apr 21 10:13:31 kernel: task: ffffffc02ff2e140 ti: ffffffc022f3c000 task.ti: ffffffc022f3c000
Apr 21 10:13:31 kernel: PC is at 0xf6aecb74
Apr 21 10:13:31 kernel: LR is at 0xf6700018
Apr 21 10:13:31 kernel: pc : [<00000000f6aecb74>] lr : [<00000000f6700018>] pstate: 20000010
Apr 21 10:13:31 kernel: sp : 00000000f6a28878
Apr 21 10:13:31 kernel: x12: 00000000f670001c
Apr 21 10:13:31 kernel: x11: 0000000000000010 x10: 00000000f6700010
Apr 21 10:13:31 kernel: x9 : 00000000f6a28a44 x8 : 0000000000000002
Apr 21 10:13:31 kernel: x7 : 00000000f6700010 x6 : 00000000f6701608
Apr 21 10:13:31 kernel: x5 : 000000000001f9f8 x4 : 00000000f6a288e4
Apr 21 10:13:31 kernel: x3 : 0000000000000027 x2 : 0000000000021000
Apr 21 10:13:31 kernel: x1 : 0000000000000000 x0 : 0000000000000027
What does this mean?
Edit:
AX88U - main router
Diversion
Skynet
Connmon
Dual Wan Failover
AX86S - AiMesh node
/jffs/.asdbk# ls -l
Try this:
head /jffs/.asdbk/main_checker.sh_bk
cp /dev/null /jffs/.asdbk/main_checker.sh_bk
df /jffs
HI, long time lurker first time poster. I too have the same issue with this release with a couple of devices on the Guest network. Toggling to WPA2 only worked but not with WPA2/WPA3. The 2 devices were a Petlibro cat feeder and Eufy doorbell. Weirdly they connect to the "main" ssid fine , just not the Guest network unless setting WPA2 only.
Was this release removed for the RT-AX88U_PRO? I'm not finding it within that area. I do find it for the RT-AX86U.
See the OP post:
List of models that are not included in thise release, as they will be included in the next 3006.102 release:
  • GT-AX6000
  • zenWifi Pro XT12
  • GT-AX11000 Pro
  • GT-AXE16000
  • RT-AX86U Pro
  • RT-AX88U Pro
