Release Asuswrt-Merlin 3004.388.9 is now available
Two fixes from this post are in version 388.9 or should we wait for a higher version?
That post contains issues reported after the 388.9 release, and which should be fixed in the next release.
Any considerations to adding the WPA issues so users are aware without digging through previous threads and posts?
Everything wifi related is outside of my control.
Are you only listing reported known issues that are within your control for some reason? or all known issues related to the firmware? That last reply didn't clarify that.
Either if it's in your control or not, it's still a good consideration to have to save people re-reporting it as seen in the threads.
Especially considering it's something someone would want to know about *before* flashing; whether it's in your control or not.
I only list issues that I have confirmed for a specific release. I don`t list any wifi issue because, since I have no control over them anyway, I don't devote time in trying to confirm whether they are firmware issues or end-user issues.
Understood, so to summarize I understand correctly, anything listed there is confirmed by you, but if you haven't devoted time to confirm it, then it doesn't get listed.
The only reason I mentioned is only because it might of helped 'some' users before flashing (assuming they read the notes that is).
I realize even reading the notes sometimes doesn't happen though; so the value may be limited. I for one would of noticed and factored that in if it was listed as a known issue for example.
Consider donating your own time to do this if you think others would benefit?
I'm not sure I understand what your suggesting? I can't edit his post to add known issues.
I think you will find @ExtremeFiretop‘s time is otherwise usefully engaged elsewhere supporting users of the firmware, in particular one of its extremely valuable addons, of which he is the author.
Thank you @jksmurf; ,i'm thinking maybe he meant my time testing and reporting these issues maybe?
But i do, as you know I've reported the issue initially in alpha and my troubleshooting in my thread and followed the reports in this thread closely.
So I do donate whatever time I have to the community when I can. All I was thinking is although this is one of those issues out of @RMerlin s control, it might of helped highlight the issue more if it was validated. But I realize @RMerlin has limited time to donate as well, and can't be spending time validating issues outside of his control. Which was his point initially if I understand correctly.
Absolutely, and as you recall I followed your concerns on a specific issue, with @aex.perez, in your own thread, before you brought it across to the release thread.
It’s often difficult to know exactly what someone means by a particular statement, so I’d have to give him the benefit of the doubt. I’m sure it was meant well, but my interpretation was that all the issues that were known that were outwith Merlin’s control also be collated and reported, so users could decide (to install or not).
However I am not sure you’re best placed to perform such a function, it would require reading and reviewing all posts associated with a release, deciding if it was a reproducible issue, one that was outside Merlin’s control and listing that.
It sounds a time consuming task and once you have done it once, the expectation then becomes that you become the guardian of the Asus-only issues list, for each release. I wish you all the best with that ;-).
I am having an issue with this build on my GT-AX11000... The AiNode, USB, & system status are not appearing they are blank.. I noticed someone talking about this in the alpha discussion but the thread was closed. I have never had this problem with any build but on this build this is happening.
Have you tried an
ipconfig /flushdns
from Admin CMD prompt? (on your PC or whatever you are using for access?)
Not saying that's the answer but curious if it changes the result.
@aex.perez @Tech9
Just noticed this stock update for my AX86U citing IoT compatibility fixes - per your comments earlier in the thread. Not sure if it applies to other routers too.
Hi, I have a AX86U and just installed 3004.388.9, and I'm using a reverse proxy locally. The reverse proxy I'm using is based on nginx. I have a rule setup as follow:
I has been working fine since I set up this configuration, but with this version I noted the System Status panel is blank (If I log in using port 80, everything is fine). I'm including a screen shot of what I see when using my reverse proxy:
I updated my reverse proxy to the latest version, but I have the same issue. Any recommendations on how to fix this? Could be something introduced int this version? Thanks!
ASUS RT-AX68U fw 3004.388.9
Does the new dropbear have limitations?
I'm seeing an access problem from the Home Assistant integration:
Apr 12 09:04:13 dropbear[5255]: Child connection from 192.168.2.225:44326
Apr 12 09:04:13 dropbear[5255]: Exit before auth from <192.168.2.225:44326>: No matching algo hostkey
Igor, I just successfully tested a hack/workaround to the Home Assistant SSH issue with Dropbear 2025.87
. See https://github.com/home-assistant/core/issues/142830#issuecomment-2827806351
