willyburz
I am still stuck with my AC thought process, so I think I understand but would like some clarity. I want to make sure I'm not missing something on the wifi settings side. I know when running wifi analyzer to verify clean channels, I am at 80mhz on the 5g "Testing amazing by the way", and 20mhz on the 2.4. I assumed I could lock 160mhz instead of auto on 5g, but my AC2x2 Chromebook Pixel disconnected. I assume the only way to lock 160mhz and working is with all AX client devices only? I have currently one ax device "speed testing between 550-630 on my gig internet with that 80mhz currently" and more ax devices being purchased later this year. Majority of all current devices are AC, and I have the low tiered AC wifi stuff connected to 2.4 and my priority wifi devices on 5g. All gaming consoles are wired.
1. Is it accurate that I can't lock 160 with AC devices, or is it covering channels outside of what my regular AC clients are seeing, and that's why it won't see 5g connection when locking 160mhz?
2. How does AX on 2.4 actually work, being that it's basically stuck in 20hz all the time? Does anyone actually use AX clients on 2.4? What am I missing here?
3. Under wifi 2.4 and 5g settings, 160mhz and AX default checked on "initial check up option when setting up router" , I have all default settings basically on both 2.4 and 5g, except locking in the least interfered channels. Currently 6, and 161. I have manually set. Anything outside of this I should review or toggle?
Thanks, and appreciate the patience. Maybe I need to re-read the Duckware breakdown article?!
