AX86U | CPU core 1 spikes to 100%
toothmania
This have been so annoying for a while already, I have updated to 386.5_2 and out of nowhere my core 1 keeps spiking up to 100% which eventually kills my internet for an entire minutes and comes back again, fast forward, downgraded to 386.4 and it's the same anyone having the same issue?
Welcome to the forums @toothmania.
Did you perform a full reset after flashing the 386.5_2 firmware first, then, minimally and manually configuring the router afterward? Without using a saved backup config file. And without using a previously used USB drive that had amtm and/or other scripts installed.
The issue you describe isn't common at all. And an indication to me that the router isn't in a good/known state.
A proper reset as outlined above should give you back a stable network.
If you need further guidance to do so, the following links may be useful.
[Wireless] ASUS router Hard Factory Reset | Official Support | ASUS Global
Fully Reset / Best Practice Setup / More
Almost all L&LD Links
About L&LD
Just to add that when using Merlin firmware: If you log into the router and install htop (opkg install htop) and then run it, you can use this as a simple and quick means to see what is using your CPU!
htop requires installing Entware on an external USB drive. top on the other hand provides much the same information and comes as part of the firmware.
