sfx2000
Part of the Furniture
Some benchmarks - these can all be pulled down via 'git clone <repo>'
Some might be in entware/optware - or for distro's that wear the big boy pants, they're likely in the repo's directly...
Anyways - some items that have been shared back and forth - @kvic @RMerlin @Voxel and others...
Most of these - execute from the directory directly... might have to pull down dependencies here...
e.g. if /home/usr/sfx/builds/byte-unixbench - then that one - ~/builds/byte-unixbench/UnixBench/.Run
UnixBench
https://github.com/kdlucas/byte-unixbench
Hint - run this in the UnixBench sub-directory
TinyMemBench
https://github.com/ssvb/tinymembench
Hint - run this in the same dir as the build
IOBZone - measures storage IO
https://github.com/pantheon-systems/iozone.git
Hint1 - build in ~.iozone/src/current
Hint2 - Command line used: ./iozone -e -I -a -s 20M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 /tmp
Hint3 - you can play around with this with different paths
Hint 4- just append the commmand line with the path to test - in the example above it's '/tmp'
OpenWRT cpubench - this one includes source code
probably useless - but fun... and a good excuse for me to create a repo on github...
https://github.com/sfx2000/openwrt-cpubench.git
@Voxel and I had a bit of discussion on loops here...
There's others - iperf3 is a good one, and we'll discuss this in another post...
Other stuff -- some is github, some is entware/optware, and some is native for the OS in use...
UnixBench
TinyMemBench
