[Beta] RT-AC87U Firmware version 9.0.0.4.380_2695
sentinelvdx
Release Notes:
[Beta release]
Security Related
- Modified the access rights of account mode and share mode to asusware.platform path when lighttpd server is enabled. (Très Acton at BAE Systems Applied Intelligence)
- Modified the access rights to specific port of UPnP server. (Thanks to Acton)
- Updated lighttpd server version to 1.4.39 (Thanks to Tommi)
- Restriced access from wan method to enhance security. (Thanks for David)
- Changed SSH and Telnet default access interface.
New Features
- Supported auto dynamic port changing of UPnP server when ports conflict.
- Supported more ASUS Router App new features
- Added traffic analyzer
Bug fixed
- Fixed the GUI issue for reboot scheduler
- Fixed httpd/ Telnetd/ SSH restart issue after LAN address changed
Download: Click Here
thx for info :)
I'm right now using it. So far on the DDNS registration I've noticed this one does not register saying unable to connect to internet, once I go to other tab and back to DDNS tab and re-apply the alias, this one registers succesfully again.
Also the firm 3.0.0.4.378.9529 had battery drain issue solved on my Galaxy S6 w/6.0.1, I'm going to check if here stays the same.
@sentinelvdx
On Merlin 380.58 is still the 37.3.0.50 Quantenna Firmware Version.
Is in this Beta a newer one.
how we can check qtn drivers version under OFW ?
What is OFW? I've seen it used a few times now in recent posts but still haven't seen the definition for it.
Official FirmWare
OFW = Offical Firmware?
Through SSH:
qcsapi_sockrpc get_firmware_version wifi0
So far working well here with a more stable 5Ghz signal, we will see in few days.
Through SSH:
thx RMerlin
VANT@RT-AC87U:/tmp/home/root# qcsapi_sockrpc get_firmware_version wifi0
37.4.0.56
i found bug.
time is not synchronized in my system. I do factory default many times and time sometime synchronized but more not synchronized.
i found bug.
That's totally true... same here
thx RMerlin
37.4.0.56
Thank you. It is a New driver.
I hope merlin is able to install the new driver in his next firmware. 380.59
Asus please fix time synchronization bug, then we can test this fw, and 5GHz band
Merlin, do you think you could provide us users of AC87U with an updated 380.58 with the new wifi driver? I believe this has the potential to be the ultimate firmware for most AC87U users.
Thank you!
This version finds two BUG!
1 open the visitors network, set the time, when the time to reach the set time, the visitor network will not be closed!
2 traffic monitoring can not be used!
Thank you!
I can't do anything without its source code, and since this is a beta, the source code is not available.
Sent from my Nexus 9 using Tapatalk
