dugaduga
I'm trying to block incoming / outgoing IP's with AsusWRT firewall; most of these blocks take place only after Skynet is initiated; But what I am doing is looking to accomplish is blocking an IP prior to Skynet initiation.
I've tried the following for example:
None of these examples are showing up in the log; So I'm not sure if it is working. Only after Skynet initiates do I see any custom entries blocked. Any help appreciated! Thanks.
iptables -I OUTPUT -D 8.8.8.8 -j DROP
iptables -A OUTPUT -D 8.8.8.8 -j DROP
iptables -I INPUT -s 8.8.8.8 -j DROP
iptables -A INPUT -s 8.8.8.8 -j DROP
and
iptables -I OUTPUT -D 8.8.8.8 -j DROP LOG --log-prefix "[BLOCKED - OUTBOUND] " --log-tcp-sequence --log-tcp-options --log-ip-options 2>/dev/null
