Time scheduling not blocking devices
halcy0n9001
AX-86U Pro running 388.2.2
I have set-up time scheduling for a device but it still has internet access outside the configured hours.
The time scheduling is set to Time in the ParentalControl.asp view, the hours are configured, enabled and applied.
If I use Block the device cannot access the internet, but prefer for it to be on a timer.
Anyone else had this issue or is using this feature and it's working as expected?
Lastly is there a shell command I can use to check/config this?
Thanks!
Thanks, the device doesn't have a manually assigned IP. But is on the guest network, perhaps that's why the scheduling doesn't work. I've just blocked the device for now.
