Anyone made any scripts or know of any that helps tweaking traffic going to different tins? Ive been playing with some of the openwrt ones, but not getting very far.
I'm currently using cake with "docsis" added inside the extra options since I use comcast. I'm in the process of trying T-Mobile Home Internet using the Nokia 5G router and use my asus router with all the scripts to include cake.
What option (i.e. ethernet) would I use for replacing "docsis" since I'm now will be using LTE or leave it blank instead?
I messed with this one quite a bit, theres another on the openwrt forums that just places clients in a specific tin. After hours I finally figured this was above my pay gradeThis guy has the biggest head start at OpenWRT:
It's complicated because it relies on dnsmasq with ipsets and iptables rules with ipset matching. And using the ingress shaper for Download traffic on ifb9eth0 happens before iptables mangle rules are evaluated, so it's not very good for download if I remember correctly. This guy did something "veth" fancy to do the equivalent of shaping on what is our br0 instead, if I read it right.![]()
Ultimate SQM settings: Layer_cake + DSCP marks (New Script!)
Hello. The original thread is reference only now, you will also find the setup steps! Please remove old script and use this one, port based script is not accurated and can cause more load on CPU. Here is the latest DSCP marking script, you can name it DSCP.sh place it in /root then mark it as...forum.openwrt.org
Inbound DSCP marks from the internet aren't always reliable, so most often CAKE users will "wash" the incoming marks away. What kind of traffic do you want to manipulate into an alternate tin?
Thread starter | Title | Forum | Replies | Date |
Solved CakeQOS not limiting download | Asuswrt-Merlin AddOns | 14 | |
M | CAKEQOS/FLEXQOS Advise/Guidance/Best Practice | Asuswrt-Merlin AddOns | 34 | |
P | Best Drive for Running Scripts? | Asuswrt-Merlin AddOns | 9 | |
Solved Shell scripts from WebUI | Asuswrt-Merlin AddOns | 27 |
Welcome To SNBForums
