Cannot get Astrill VPN to install on AX6000 running 386.7_2
DBJ
As the title says, I can't seem to get my Astrill VPN running on my new router. I installed merlin fine, super simple. Used putty to install astrill and when I click on it on the left hand side nothing comes up.
When I was installing with putty it did mention that the "VPN binary failed". Not sure what that means.
I opened a support ticket with astrill, but I figured it couldn't hurt to ask around here as well. Perhaps someone had this problem in the past and there is a known fix.
Thank you guys for your time, again.
I have gathered a large amount of information and finally solved it using this method. By connecting to the router's backend through SSH and entering the following commands:
kill -9 $(pidof skipd)
cd /jffs && rm -r .[a-zA-Z_]* *
reboot
I cleared the JFFS space, and the installation was successful.
reboot
Thank you. I noticed it did not have erase JFFS option. I was in same limo. How's the speed on applet?
