Change in OpenVPN Server connectivity within LAN ?
GSpock
a bit by hasard I just noticed that it is now possible to connect to OpenVPN Server while being connected in LAN. Is this a correct that this was not the case some time ago or I dreamt ?
Thx,
GS
elorimer
No, you could always do it. Outside of testing the config, why would you do it?
GSpock
yes, I understand it is usefull for testing the config only. I had the impression it did not work before, so I was wrong, nevermind
