I'm looking to purchase an affordable/cheap wireless router to share my internet.
I've been searching for some time and narrowed my choices.
But i need some help:
I can't decide whether to buy a WRT54G2, WRT54GL, DLink DIR-615 or a TRENDnet TEW-652BRP or some other similar product i missed.
I know that the advantage that the GL has over the others is the ability to use third-party firmwares which add a lot of features. But what would the third-party firmwares' advantage be in a small home network that's gonna be used primarily for internet with a max of 2 laptops (one is running vista) connecting wirelessly and 1 wired desktop?
I actually like the GL and the ability to customize it, but the G2 is better looking with a faster cpu and the D-Link and TRENDnet both support 802.11n.
So can someone tell me which way to go? Customizable? New? Fast?
Thank you.
P.S.: I want to be able to connect from 12-15m (40-50ft) away and a concrete wall in between.
Thank you.
