Solved Cron job not running?
XIII
Goal: automatically make a nightly backup of configuration files on my router and Raspberry Pi's, using rsnapshot, to an attached USB drive (and to OneDrive via rclone).
I think I have correctly configured rsnapshot/rclone, because manual runs do what I want.
However, the automation seems to fail...
In /jffs/scripts/services-start:
cru a BackupDaily "0 1 * * * sh /opt/bin/rsnapshot daily"
Output of cru -l:
0 1 * * * sh /opt/bin/rsnapshot daily #BackupDaily#
So I expected this script to run this morning at 01:00, but that did not seem to happen (no backup on the USB drive)
What did I do wrong? How to debug?
Chiny91
Did you reboot your router, that is, re-run /jffs/services-start ?
If not, you can add a cron job manually (saves a reboot) in a terminal:
Don't forget to preserve everything over reboots (and wear out your nvram):
nvram commit
If all above is correct, then take a look in the logs, starting perhaps with /var/log/syslog. If still no joy, then make rsnapshot more talkative by adding -v or -vv (I'm not familiar with rsnapshot), re-run and re-check the logs.
eibgrad
I don't know if this is the difference, as I don't use rsnapshot, but if it's a binary rather than a script, there's no need for sh.
XIII
  • Yes, I manually ran /jffs/services-start (the "cru -l" command would not show the entry otherwise?)
  • I was not aware "nvram commit" is needed for a file that is saved (on the JFFS filesystem). Are you sure? (I have never done that...)
  • Only log line for 01:00 is a Skynet line: Skynet: [#] 48665 IPs (+0) -- 1690 Ranges Banned (+0) || 30146 Inbound -- 500 Outbound Connections Blocked! [save] [1s]
  • rsnapshot is a shell/Perl script (first line: #!/opt/bin/perl -w)
ColinTaylor
Part of the Furniture
nvram commit is not required as it is not relevant for jffs scripts.
I suggest that you pipe the output of your cron command to a log file so you can see any errors that it throws:
cru a BackupDaily "0 1 * * * sh /opt/bin/rsnapshot daily > /opt/tmp/rsnapshot.log 2>&1"
XIII
Good suggestion! I forgot that my rsnapshot config already writes to a log file...
[2021-03-02T20:41:09] /opt/bin/rsnapshot daily: completed successfully
[2021-03-03T10:00:14] /opt/bin/rsnapshot daily: started
So it looks like cron did not even execute it at 2013-03-03T01:00...
dave14305
So does this run OK interactively?
Make sure rsnapshot is executable (chmod u+x /opt/bin/rsnapshot) and remove the sh from cron since it’s a Perl script.
XIII
Got it working thanks to the help in this topic!
Without seeing Dave’s post (this morning) I decided to run sh /opt/bin/rsnapshot daily (yesterday) on the command line and got all kinds of errors.
Removing sh, as suggested by several people, solved it (and I now have an automatic backup from 1:01 today). Thanks!
