fbreve
Is it possible to set Asus RT-AC68U to work as DHCP relay?
I have Dual WAN and I am using a TP-Link TL-R470+ to load balance, since Asus firmware cannot handle Dual WAN without a bunch of bugs that make it unusable.
So, I'm currently using Asus in the Access Point mode. However, I'm missing Asus QoS, since TL-R470+ does not have it.
I would like to use Asus QoS, but not its DHCP and NAT, so I could avoid double NAT and also make rules on TL-R470+ to use a specific WAN depending on the source IP.
