Disabling USB 3.0 on an AiMesh child ?
MarcoPolo
Hello,
To avoid interference, I disabled USB 3.0 (I'm on USB 2.0) on my main router (AX88U), but how can I do the same on my AC68U router, which is an AiMesh child of the AX88U, please ?
Thanks in advance
Do you have a USB drive plugged into the node? If not then it doesn't matter what the USB mode is.
Yes, I have one device connected to the USB 3 port and one connected to the USB 2 port of this router.
What interference are you experiencing?
Interference with a zigbee coordinator that I can't get too far away from the router's USB 3.0 device/port.
I'm sorry, but the questions you're asking about what's connected to my USB ports and what kind of interference it is, is it because there's no way of modifying the behavior of the USB 3.0 port on an AiMesh child?
