DNS leak test fails with merlin/asus nordvpn setup?
Silent-OCN
I'm having trouble when using latest version of merlin firmware in my asus rt86u router.
I tried to set it up using instructions from nord and it seems to work OK with my ip showing as the nord server location. However when I do a dns leak test it goes to a server in Germany not owned by nordvpn?!
Soon as I remove merlin firmware and install nord open vpn the dns leak test works fine on udp and tcp?
Anyone know why this is please?
Silent-OCN
What DNS servers does it go to?
For some reason ONLY on my mobile phone connected via WiFi, it shows a German DNS. The ip address doesn't match what any other website showing my ip shows.
On ethernet standard and extended dns leak test both show the correct ip and no dns leak.
Any idea why my phone does this?
SomeWhereOverTheRainBow
Part of the Furniture
They may be the servers geolocated closest to the nord vpn exit point that the client is using. That maybe why you are seeing a German DNS on the leak test.
Silent-OCN
what servers does it show?
Names? IP’s?
What OS is your phone and what browser are you using?
The ISP is called data camp Ltd, based in Munich Germany.
My phone is samsung galaxy s21 running android 12. My ip address on first page of dnsleaktest.com starts 105.xx.xx but when I click standard or extended test it shows ip as 195.xx.xx.
I just find it bizarre that this only happens on my phone connected to WiFi. I'm in UK and have selected a UK NORDVPN server.
On ethernet this 'leak' doesn't occur.
FWIW I spoke to nordvpn tech support about this last time and they confirmed that the German server is not theirs. But every device ethernet and WiFi I go on shows me as having the correct UK based ip address, and nordvpn website says my ip is protected.
I use brave browser on phone. Tried Firefox same result.
Try changing the DNS accept policy of the vpn to Exclusive. If that doesn't solve the problem, try using some of the other dns policy modes.
Tech Junky
It's not odd the phone is using secure DNS to bypass the VPN. I have this issue with pinhole being bypassed periodically and just toggle it in and off for chrome and it's back to normal blocking things.
Silent-OCN
This might sound stupid, but in the asus router login under VPN there is a few headers.
VPN STATUS - Shows connected to openvpn.
VPN CLIENT - Shows ON and connected.
VPN SERVER - Shows OFF and nothing there. Should there be something under this heading on also?
How do I know for definite that this isn't just a bug and the vpn actually isn't working properly?
Vpn client is what you are concerned with.
Silent-OCN
Ok thanks. So how do I know for sure then that this is just something to ignore, and that my vpn is actually working properly? It's funny how this issue only arises when I use merlin. On stock asus firmware it doesn't happen.
Gary_Dexter
Use a different browser on the phone.
same result?
