IsaacFL
I have switched my Merlin Asus RT-AC1900P to operate in Access Point mode. Using firmware 384.4_2 and did initialize after switch.
Everything is working ok as far as access, etc.
On Administration-System-Local Access Config:
Authentication method: Both
under Installed Server Certificate it has
Click here to manage:
Clicking takes me to the WAN-DDNS tab.
I enable the DDNS client, set up my ddns server (domains.google.com) with all my information:
Apply, and it says for server certificate status: Updating...
This had all worked when I was using it as a Router, so I am thinking that in AP mode it does not?
Notice that the DDNS update is not happening when I check google domains (my wan ip has changed in the meantime, so know that it isn't updating.)
I am thinking the ddns update part is not starting up in AP mode?
