DomainVPNRouting Domain-based VPN routing script
johndoe85
@Ranger802004
Can you add number to this script when you update the policy rules?
It's annoying to have to type the policy name every time a change is made.
An option would be to process all the policys at once. But a number would definitely be very handy.
(I had to make a new thread since there are some stupid blocks on this forum that prohibites posts in threads older than 6 months. Great idea huh?) @thiggins
@Ranger802004
I second that...It's "lazy" but is simpler and faster :)
@Ranger802004
Post your request via GitHub issues on the repo and I will look into your request from there. Also you can always manually run the command to process all policies with the 2nd argument as “all”
