DSL-AC68U No DSL light
OK, you may have to fill in something to get it started at all.
Didnt take care that his modem never ran before on a line.
Cant test it now as I've been upgraded to Vplus and sold mine.
Could you please be so kind and test it with changed username or pw?
Then it should sync, but without internet connection.
If it is like you say there cant be any bridge mode (modem only mode) where you set credentials on the client side or the router behind the modem.
I am able to set it in bridge mode, then the dsl light is also off
Sent from my SM-A505W using Tapatalk
OK, sync is OK, but no matter what parameters I change, I'm not able to have an authentication.
I'll try to get some clues from others ISP customers in the week and make some tests next week-end when I'll be back home.
DSL light might indicate working internet-IP-connection, not that the line synced. On other routers there are different LEDs for those.
You should see sync in GUI.
